Case Mod - Complete ⭐ ZOROG project #CMWS19Finals
Discussion in 'Project Logs' started by neSSa, 11 Jan 2019.
  1. neSSa
    neSSa Multimodder
    11 Aug 2014
    Progress...
    Cheapskate likes this.
  2. neSSa
    neSSa Multimodder
    11 Aug 2014
    Acrylic parts for custom reservoir is finished, I'm looking for a sealing rubber and making threads for screws...
  3. Cheapskate
    13 May 2007
    Ack! Screws ruined your velour chair!
    That's a lovely plate. Will you buff it out?
  4. neSSa
    neSSa Multimodder
    11 Aug 2014
    Hehehe, the armchair is okay, I plan to assembly it for the next few days and put it in the case :)
  5. neSSa
    neSSa Multimodder
    11 Aug 2014
    New fittings from EKWB is arrived, it's beautiful and perfectly fit for ZOROG hard core project style, thanks again for support :)
  6. Cheapskate
    13 May 2007
    Those blocky fittings would be great in polished chrome.
  7. neSSa
    neSSa Multimodder
    11 Aug 2014
    @Cheapskate, this black fittings is perfectly fit for all color, I will use copper tube with nickel plated in ZOROG project ;)
    1/4 tread drill is arrived, everything is prepare for assembly...
    First I make test, everything is OK...
    and go to asembly...
  8. neSSa
    neSSa Multimodder
    11 Aug 2014
    Custom distro/reservoire is done! :)
    censored_Prometheus_ likes this.
  9. neSSa
    neSSa Multimodder
    11 Aug 2014
    progress...
  10. Cheapskate
    13 May 2007
    The reservoir nearly disappears in that big-as* case.
    neSSa likes this.
  11. neSSa
    neSSa Multimodder
    11 Aug 2014
    Front :D
    Work, work, work ...
  12. neSSa
    neSSa Multimodder
    11 Aug 2014
    I
    I really don't understand you, try ti watch all worklog, maybe find answers?
  13. neSSa
    neSSa Multimodder
    11 Aug 2014
  14. neSSa
    neSSa Multimodder
    11 Aug 2014
    Work on the back side and cable management...
  15. neSSa
    neSSa Multimodder
    11 Aug 2014
    Ready for tubing :)
  16. neSSa
    neSSa Multimodder
    11 Aug 2014
    Cooper tubing :)
  17. neSSa
    neSSa Multimodder
    11 Aug 2014
    Tube are ready for nickel plated!
  18. Cheapskate
    13 May 2007
    Looks perfect. :D
    5/8"? I thought Europe was all on the 12mm standard?
  19. neSSa
    neSSa Multimodder
    11 Aug 2014
    Thank you @Cheapskate, yup this is 5/8" almost 16 millimeter, with nickel that is it :)
    So shiny :D
    Dot_Kappa and arduum like this.
  20. neSSa
    neSSa Multimodder
    11 Aug 2014
    Progress...
    Vandalo and Dot_Kappa like this.
