Graphics Zotac 1060 mini 3GB - Fan replacement
Discussion in 'Tech Support' started by MrJay, 8 Apr 2018.
  1. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Long story short,
    I have one but I've lost the recepit, the fan is pretty much hanging off (common issue with the mini series of Zotac cards). So RMA is out of the question.
    Anyone had any experience with replacing fans on these cards? It appears removable, has three mounting screws and is circa 90mm.
    I was going to bung an aftermarket cooler on it but as itsi a mini it'll void it's original use case....of actually being mini!
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
  3. MrJay
    20 Sep 2008
    Nice find buddy,
    You ability to query Amazon is superior to mine! I'll take the old fan off and measure it up later, see if I can find something that'll fit.
