Build Advice Zotac Fusion and Sim Slot for Sierra GPS/3G card
Discussion in 'Hardware' started by minime, 9 May 2011.
  1. minime
    minime What's a Dremel?
    3 May 2011
    Hi all,
    I have just installed a Sierra GPS/3G unit in to the mini Pcie space on my zotac fusion board (removing the Wifi card). But can any one recommend a simple enough solution for adding a sim slot or even where I can buy one from that could work?
    Never worked on 3G/GPS with Mini Pc's before but I have seen: http://t0.gstatic.com/images?q=tbn:ANd9GcRT7b0IIkwehXL0D24ordFWj6Tz8IR0jC4YTuT-gjs3vwXy_PNB
    Seems like an easy solution just can not find one anywhere with the cable :jawdrop:
    Any help or input much appreciated.
    Many Thanks
    Eric
