Reviews Zotac Gaming GeForce RTX 2080 Ti Amp Review
Discussion in 'Article Discussion' started by bit-tech, 26 Sep 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Guest-56605
    Guest-56605 Guest
    A sub standard product rushed to the market by Zotac doesn't really bode well, their 10** and 9** series cards were of sterling quality - not enough stock of Nvidia's over priced PCB's to go around I suspect...
  3. Mr_Mistoffelees
    26 Aug 2014
    £1224... :duh:
    GTX 1070ti £417 a few weeks ago. :grin:
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    From Derbauer's testing with the 2080 OC, you gain more performance from focussing purely on memory OC and leaving the power target and core speeds/voltages stock (and on the standard fan profile!) then from core OC with power target maxed:
    Power-mods and sub-ambient gain effectively naff-all at the cost of wasted power.
    Looks like the optimum OC strategy is to push the memory has hard as possible, then inch up the core speed from there.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I've never understood why the majority of partner cards always seem to avoid OC'ing the memory, especially considering (afaik) partners source their own RAM modules and could bin them for higher clocks.
  6. Paradigm Shifter
    10 May 2006
    I suspect it's a combination of laziness - it's easier just to up the core clock a few tens of MHz and call it done - than it is to tweak the VRAM up and make sure it's still stable and not artefacting... and making sure that you can maintain a particular SKUs advertised clocks. It would be a bit embarrassing if a later batch of GDDR5(X) wasn't quite so good so you had to back off the default clocks. Not to mention potentially opening up to a court case.
    I had a pair of 4GB GTX670s at one point - bought at the same time, from the same place, similar serial numbers... one could handle a fairly serious boost on the VRAM clocks, the other would get flaky after a (by comparison) minor bump in clocks. They could both cope with essentially the same core clock speed. I know, I know, anecdotal evidence, but I'm guessing that one chip in the "poor clocking" card was right on the edge of stability just above its rated clocks and any more just pushed it that little bit too far.
    I've long had mixed experiences overclocking GPUs. My 7900GTO would overclock like a trooper; same with an 8800GT. A pair of 460's hated being overclocked (but the coolers were terrible so I wasn't surprised). The aforementioned 670s were a mixed bag. I had a 970 which did OK, while the Titan X (Maxwell) in my sig hated being overclocked, but it spent its life mostly on compute loads, so I wasn't worried.
    Corky42 likes this.
  7. GeorgeStorm
    16 Dec 2008
    Not all cards (of the same model) come with mem from the same manu, guessing due to changes in supply prices etc, but considering some mem acts very differently, some needing volts to clock further, others not etc, there's more potential variance so easier to leave stuff at 'stock'.
    Paradigm Shifter likes this.
  8. Paradigm Shifter
    10 May 2006
    A much simpler (and shorter) way of explaining my waffle above. :D
  9. GeorgeStorm
    16 Dec 2008
    Haha, well yours is slightly different I got the feeling, as you were pointing out it's another thing to monitor, even if you have the same mem chips, doesn't mean they'll clock the same depending how far they want to push them.
    My point was an extra potential issue :p
  10. edzieba
    14 Jan 2009
    Same reason they are fitted with massively oversized inefficient coolers covered in plastic greebles and glowing bits: consumers perceive bigger = better, regardless of actual testing. Moar GPU clock therefore mean moar better.
    All the consumer cards will be using Micron's GDDR6 at launch (Samsung are supplying GDDR6 for the Quadro RTX cards), though that will likely change over time.
    For manufacturer overclocking, that's the same situation as always with GPU memory (apart from HBM): chips need to be binned by the vendor after receipt, which can either be on a dedicated rig (per chip binning) or just bung them all onto boards and post-tested to pick the cards that happen to end up with the better chips to sell as the higher SKUs (much cheaper than per chip binning, but 'wastes' some better chips on lower SKU cards).
  11. GeorgeStorm
    16 Dec 2008
    Fair enough, I was talking from a more general point with gpus, haven't paid any attention to the rtx launch.
    Still doesn't rule out there being variation over the coming months/years though no?
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    Certainly doesn't, but it is up to the AIB (or their OEM depending on which AIB we are talking about) to order the memory in the first place, so it wouldn't exactly be a surprise to them.
Tags: Add Tags
