Hardware Zotac GeForce 8800 GT 512MB AMP! Edition
Discussion in 'Article Discussion' started by Tim S, 11 Feb 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. kenco_uk
    28 Nov 2003
    I agree with your review - for those that require a single slot solution - this is the cats whiskers. Otherwise, look elsewhere for your screen-filling polygon-prodding wundermachine.
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Wow - I thought my Asus EN8800GT (Glaciator Cooler model) temps were high at 47 Idle 65 Load! This only goes up by 5 degrees when overclocked to 700/1750/2000 as well!
    Looks like I have some room to play compared to the reference model then!
    Nice review though, I do agree with your conclusion though. My card was £179 when I bought it at the end of December. Most 8800GT's at stock speeds are now £30-40 less.
    But that's the way the cookie crumbles I guess!
  4. Whalemeister
    Whalemeister is so hot right now!
    27 Nov 2007
    Great review and it looks like a nice 8800GT OC'd to it's limits, but I really don't see the point in this card when an 8800GTS costs about the same and can OC'd higher...
    Oh and you refer to the "Dinosaur Theme" on the card and box, it looks more like a dragon to me as I don't remember any fire-breathing dinosaurs from my last visit to the Natural History Museum ;)
  5. Tim S
    Tim S OG
    8 Nov 2001
    Yes, you're probably right - I wrote this pretty late at night :blush:
  6. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Could it not be a fire breathing dinosaur? That's about as steeped in reality as a dragon is.
  7. badders
    4 Dec 2007
    There are some things that are acceptable, and others that just aren't.
    I fire-breathing dinosaur? Come off it!
  8. Bauul
    7 Apr 2007
    So a mythical winged lizard is ok, but a real life animal who just happens to gozz liquid napalm is crazy? Foul play I cry! Why do you think the dinosaurs died out if it wasn't for them accidentally setting everything on fire? The evidence is undisputable.
  9. trig
    trig god's little mistake
    10 Aug 2006
    nice mem...wish i could get there..
  10. aggies11
    aggies11 What's a Dremel?
    4 Jul 2006
    By playing with my own 8800GT, I've come to think that OC in terms of video isn't necessarily as interesting as it seems. Idealisticly, assuming that the graphics card was the only component in the machine, a %10 overclock would lead to a 10% increase in performance, ie. framerate. Seeing that I am struggling to get Crysis playable at my desired settings, benching around 25fps average. A 10% overclock would only yield a boost of 2.5fps. While every little bit does count, it's not really enough to push me into the smooth/playable realm. Hardly a big boost or anything.
    At higher performance levels (eg 60fps) an OC like that leads bigger results, but then at that point you don't really need the extra performance anyhow. I'm guessing that performance games in the neighborhood of %30 or so would become meaningful, but from an overclock (on the 8800GT at least) thats not very realistic.
    So personally I'm not sure it's worth all the extra bother, as the impact vs investment (either in buyingi a PRE-OC'd card, or going through the trial/testing required to do it yourself) doesn't really justify itself.
  11. neal
    neal What's a Dremel?
    27 Apr 2008
    8800gt are quite cheap now...i mite get the overcloed evga
Tags: Add Tags
