Hardware Zotac H67-ITX WiFi Review
Discussion in 'Article Discussion' started by Claave, 21 Jan 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    Pretty cool. If I ever got round to building a sff pc I would be very keen on one of these
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    The BIOS at least managed to run our test memory at the maximum 1,333MHz that the P67 chipset supports.
    Page 7 dude, I think you meant H67 ;)
  4. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    No power consumption info?
  5. D B
    D B What's a Dremel?
    11 Apr 2004
    For a briefest moment I lost my head and thought ... Dang! 33 FPS in Cryses with the built in graphics??!!!
    ....then I came to ;-)
    (wouldn't THAT be something though?)
  6. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Hmmm I am awaiting the the review of the Foxconn H67-S board as at £69 it makes for a perfect temporary mITX board until the full fat P67 models come along.
    I am sorely tempted to change my Sandy Bridge build to a mITX form factor based around the excellent Silverstone SG07.
    My idea was cheap H67 & 2600k now and then move over to the P67 when it comes out.
  7. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    I have the H55 Zotac board and I liked the fact I've been able to OC my i5 665K !
    Not likely to bother upgrading as it's quiet enough and doesn't need any more CPU muscle to be a decent HTPC build.
    dunx
  8. Xir
    Xir Modder
    26 Apr 2006
    Woohoo! Crysis tests again!
    Howcome Crysis is considered too old for garphics cards tests, but stays in the Mobo tests? :lol:
    (And yes, it still is an application that REALLY taxes your system)
  9. tozsam
    tozsam What's a Dremel?
    11 Jun 2010
    What happens to the CPU's built in GPU when a graphics card is added to the motherboard? Does it add to the graphics grunt, or simply get deactivated?
  10. Ipatinga
    Ipatinga Don´t bother... I´m right
    10 Nov 2010
    I like Zotac boards, but previous problems like "bricked bios" and "motherboard physical revision to correct some mistakes that disabled some cpu options" just sent me to Gigabyte and Asus.
    Asus P8H67-I Deluxe is not cheap, but I found it to be a better deal... feature wise and less chance of problem in the future. Hope Gigabyte can deliver their GA-H67N-USB3 fast enough and even the much talked about GA-P67N version (if it's true)... to see how prices will turn out.
  11. stupido
    stupido What's a Dremel?
    30 Nov 2009
    I also wait for a P67 based mini ITX to build powerful gaming/HTPC box...
    this one could be quite good for classic HTPC or daily used PC that requires some more CPU muscle and not that much GPU muscle... except the price is a bit too high for such system...
  12. xaser04
    27 Jun 2008
    Indeed, the motherboard is excellent (CPU socket location aside) but the price is just too high for this sort of board. The Foxconn (whilst lacking some features) is half the price...
  13. miester7
    miester7 My single core cpu plays crysis
    13 May 2010
  14. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    The Foxconn review is due to go up on Monday morning so not long to wait guys.
  15. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    What the Zotac has going for it is those 6 SATA ports. If you want to build a top high performance NAS then you really need 5 SATA ports (one for the boot drive and 4 in RAID 5 or RAID 1+0). Shame the IO performance isn't up to par really.
  16. sear
    sear What's a Dremel?
    2 Aug 2010
    Probably because it puts strain on all parts of your system... memory, hard drive, motherboard, CPU and GPU all factor in to Crysis' performance, rather than just the CPU and GPU like so many other games. Crysis does things when it comes to AI, graphics etc. that most other games don't even come close to; I think only ArmA II is more advanced than Crysis.
  17. TheLostSwede
    TheLostSwede What's a Dremel?
    12 Sep 2005
    Wow, what a sloppy review, what's going on bit-tech? You're really losing your touch as a reliable source for good reviews :(
  18. dunx
    1 Sep 2010
  19. dunx
    1 Sep 2010
    Till it fried it's VRM's... RMA in progress !
    dunx
Tags: Add Tags
