HTPC ZOTAC ION mITX mobo - single or dual?
Discussion in 'Hardware' started by phinix, 19 Jan 2010.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, I'm planning to buy Zotac ION mobo, but don't know which model should I pick.
    I want to use it as full HTPC, able to play HD blueray at full 1080p, dvd, divx, xvid, etc...
    Is there a huge advantage getting dual core 330 or should I go with single 230?
    Also, I wnat to get one with onboard PSU.
    Dual core with psu and wifi would be Zotac N330 IONITX-A-B.
    ANyone used it before? WOuld this mobo be ok to use with Windows 7?
  2. stonedsurd
    11 Mar 2009
    Basically, the dualcore 330 handles flash/hulu/etc better. Otherwise the GPU takes most of the load anyway.
    I would take the 330 simply for the promise of more power :p
  3. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    Hi Phinix,
    I had one of these IONITX-A-B with an on board PSU.
    No problems with Windows 7, but at the end of the day ATOM is an ATOM, and you can't expect much. I have sold it, and now I'm waiting for the new Zotac H55-ITX WiFi to combine with an I3 and a low profile gaphics card.
