Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 26th Jan 2010, 21:06   #1
LithiumDesign
3dsMax User
LithiumDesign's Avatar
LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.LithiumDesign is the Cheesecake. Relix smiles down upon them.
READ THIS FIRST: Build Advice threads - how to post them!
Okay, so you want to build a new PC and you don't know what is out there to suit your needs, or you want some clarification from other about a bundle of components you've already picked out.
Have you already read the monthly buyer's guide? This contains several different build budgets and configurations, put together by the staff writers of Bit-Tech specifically to help first-timers (and anyone else).
If you still want to post a build-advice thread, here is the solution:
First, and most importantly, read around the recently posted threads on the same topic! There are lots of folks in your situation, and it's worth reading what they've posted and encountered while building a PC to see if it solves your questions.
If you still think you can't solve your build queries, use the guidelines below to construct your build advice thread (leaving any unnecessary fields blank) and post it under the "build advice" tag. This information helps the bit-tech community to do their best in offering the right advice for everyone.
* Budget: This is the big one, so try and be as specific as possible so we don't recommend something you can't afford, or give an upper limit so we can give you a range of options if you'd rather spend less. Remember to state it in your local currency, as it will often buy you more in some countries than others, and we can provide you with relevant links to different online retailers.
* What that budget needs to include. Are you just after a base system? Or do you need to include peripherals such as a keyboard, mouse, speakers and a monitor into your budget. Or are you just looking for a motherboard/CPU/RAM upgrade?
* What the main uses of the PC will be. Different applications (i.e. gaming, video/photo editing, 3D rendering, home theatre/media playback, file servers, web browsing and word processing) will benefit from spending more money in certain areas than others, so this information is extremely useful.
* The spec of your current PC and whether you are re-using any parts from it. This is particularly useful for lower budget builds as you may be able to save money by re-using certain components from a previous system, allowing you to spend more money elsewhere. If you don't currently have a PC, you can obviously ignore this part.
* The native resolution of your monitor. This is the one thing most people neglect to include, but it is very important if your main use will be gaming as it could make the difference between us recommending an 80 graphics card or a 300 graphics card. If you don't have a monitor, say so and we'll recommend based on monitors within your budget.
* Whether you will be overclocking or not. This is quite an important point as many components are recommended based on their overclocking ability (as well as possibly requiring additional expenditure on cooling), but others may be more suited if you are not. If you are unsure of what overclocking is and whether you want to have a go at it or not, have a look at the relevant stickies or try a forum/Google search which will turn up many results. Just remember that it is relatively easy if you are well informed beforehand, and offers a free speed boost (meaning you don't have to buy a more expensive CPU), so is generally recommended around these parts unless you either won't benefit from it or will be using the PC for mission critical work requiring 100% stability.
* How much storage space you require. This is useful for obvious reasons, although we usually recommend allowing for slightly more than you actually need.
* Do you have any special requirements? You may not have even considered these yet, but can be anything from low noise/power requirements, size/space restrictions, watercooling, or any other additional features like fans/fan controllers, wireless cards, RAID cards etc. etc.
Copy and Paste this into a new post and fill it out
Budget:
Main uses of intended build:
Parts required:
Previous build information (list details of parts):
Monitor resolution:
Storage requirements:
Will you be overclocking: yes/no (delete as required)
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
Extra information about desired system:
Thanks to smc8788 for the form layout and PureSilver for the support. Mystiiks idea.
__________________
Intel Core i5 750 | G.Skill Ripjaw 8GB | XFX HD5770
Asus P7P55D LE | 500W OCZ ModXstream Pro | Antec Three Hundred
500GB + 1.5TB Samsung Spinpoint F3 | Logitech G9x | 23" LG | Windows Se7en 64-Bit
FiiO E07K | AKG K451 | NAD 3020i
Last edited by Krikkit; 30th Aug 2011 at 09:59. Reason: Added request for thread reading.
LithiumDesign is offline   Reply With Quote
Old 27th Jan 2010, 16:03   #2
javaman
May irritate Eyes
javaman's Avatar
javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.
Mind If I put the template below and make it easier to copy?
Budget:
Parts required:
Monitor resolution:
will you be overclocking: yes/no (delete as required)
javaman is offline   Reply With Quote
Old 27th Jan 2010, 16:10   #3
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
I fap to this!
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 27th Jan 2010, 16:52   #4
LithiumDesign
3dsMax User
Sure thing javaman, should I edit my post and put the unfilled version in ?
__________________
Old 27th Jan 2010, 17:01   #5
javaman
May irritate Eyes
javaman's Avatar
If you want =) I added a bit in about mobo's effectivly splitting the special requiremens section.
Old 28th Jan 2010, 20:16   #6
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
It's looking good! Might be worth asking if the current build contains a CPU cooler, that's usually pricey and might be carried over. On the other hand, if they bought it separately, it may well be that they'd know if it was transferable. Either way great work so far!
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 28th Jan 2010, 20:56   #7
barndoor101
Bring back the demote thread!
barndoor101's Avatar
barndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysisbarndoor101 can run Crysis
how about 'do they want a functional case, or one to fap to' (rephrase it if you want)
__________________
Core i7 920 @ 4Ghz // 12Gb Crucial Ballistix 1600Mhz // Sapphire HD5870 Vapor-X (x2) // 3x Samsung 2333SW // Samsung Spinpoint F3 1TB & F1 1TB // 160gb Intel G2 SSD // Asus Xonar DG
Asus P6T SE // Antec EarthWatts 750W Modular // CM HAF922 // Corsair H100 // Logitech G11 & G5
Dell Studio 1737 // ASUS Transformer Prime
barndoor101 is offline   Reply With Quote
Old 28th Jan 2010, 22:46   #8
javaman
May irritate Eyes
javaman's Avatar
Freezer pros + OEM sometimes works out cheaper or sticking to stock is uaually ok. It should come under parts in previous build anyway.
Old 29th Jan 2010, 13:23   #9
barndoor101
surely the aftermarket cooler would depend on whether they wanted to overclock? if no then stock is fine. fi yes we can tailor something to their budget.
__________________
Old 29th Jan 2010, 15:00   #10
javaman
May irritate Eyes
javaman's Avatar
Normally yes, but sometime quieting down the system is nice too. I have found that OEM + something like the freezer pro can work out cheaper than full retail.
Old 14th Feb 2010, 13:26   #11
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Added a smidge about the buyer's guide - could be helpful in reducing the sheer volume of threads coming along.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 4th Jun 2010, 04:53   #12
songzila
Minimodder
songzila has yet to learn the way of the Dremel
i am building a new pc and this helps a lot. thanks
songzila is offline   Reply With Quote
Old 16th Feb 2011, 15:18   #13
donok
Every Little Helps .....
donok's Avatar
donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.
i should have read this before posting d'oh
donok is offline   Reply With Quote
Old 30th Aug 2011, 10:00   #14
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Added a section in the text about reading around - too many build advice threads going up at the moment really, I just feel we're covering the same stuff over and over.
__________________
Reply
Tags
build advice info
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
