Reply
Thread Tools View Mode
Old 11th Apr 2017, 02:22   #1
stealth80
Supermodder
stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.
Temporal Snow - Ryzen refresh (benchmarks included) - Complete
Hi guys, earlier this year I transferred my old build into an IN WIN 303 from a Thermaltake Core X9, due to size constraints and it's impact on desk choices. At the time I re-used my 4790k, Asus Z97 Ranger, Hyper X DDR3 Ram and added a Palit 1080 GTX Gamerock Premium, a 5" TFT screen for temp monitoring and a Crucial MX525gb SSD, before finishing it off with a Corsair K65 RGB Lux.
So here's what I have done so far:
Last week I ordered
Ryzen 1700
Gigabyte Aorus Gaming 5 Motherboard
16gb 3200 Trident Z RGB (CAS 16 - I aint paying + 33% for CAS 14!!)
2 Litres Mayhems Pastel Blue
A New Temporal Snow label
Blue and silver sleeving and PINs
20 x 3mm Blue LED (to replaced the Red LED's in the current Thermaltake Riing 12 fans)
and of course, white spray paint
Here's what it looked like under Intel
So, as you may have guessed, I'm moving this from a red and white theme to a blue and white them. It was only ever the RoG board that had me move down this route, my preferred build colours have always been blue on white and purple + green on black.
The first thing I'm going to do is post some benchmark results from my rig as it currently is as a basis to show against the new system once it's complete. I expect some trading blows and am not really doing this from a gaming perspective, more of a platform update perspective, aka my m.2 drive sits around 780mb/s as the boards m.2 is PCIE 2.0 x2, I will also gain USB 3.1 and 4 extra cores!!
So here goes 4790k @ 4.7ghz and Stock 1080 GTX (around 2050mhz on my card)
Firestrike
18129
23607 Physics - 13073 Graphics
http://www.3dmark.com/fs/12141523
The rest are ran @ 4.7Ghz and ram at 2.1ghz with the 1080GTX again at 2050mhz and are all ran at 1440P - Yes I know that the CPU's real strength is shown at 1080P, but as I own a 1440P panel, that is where my concern lays.
Deus EX: Mankind Divided DX11 Ultra + 2x MSAA - 42 FPS
Deus EX: Mankind Divided DX12 Ultra + 2x MSAA - 42.3 FPS
Gears of War 4 - 103.6 FPS
GTA V
Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 18.920017, 141.510406, 80.389191
Pass 1, 41.161190, 97.924606, 71.464363
Pass 2, 50.204746, 138.096970, 89.400696
Pass 3, 52.739799, 134.748566, 95.734879
Pass 4, 45.960644, 146.467560, 81.734024]
Rise of the Tomb Raider DX11 Ultra - 94.09 FPS
Rise of the Tomb Raider DX12 Ultra - 94.96 FPS
The Division DX11 Ultra SMAA x1 - 90.2 FPS
The Division DX12 Ultra SMAA x1 - 88.4 FPS
__________________
Project Temporal Snow - http://forums.bit-tech.net/showthread.php?t=314299 - In Progress
Temporal Snow Ryzen Refresh https://forums.bit-tech.net/showthread.php?t=323038
Ryzen 1700 @ 4.0 GHZ - Gigabyte AX370 Aorus Gaming 5 - 16GB GSkill Trident RGB 3200 MHZ - Palit 1080 GTX Gamerock Premium - Samsung XP941 256GB - Crucial MX300 525GB - Fractal Design R3 Newton 1000w White Edition
stealth80 is offline   Reply With Quote
Old 11th Apr 2017, 02:52   #2
stealth80
Supermodder
So first things first bleed and disassemble the loop and polish the block, don't want no purple coolant, whilst I was at it I figured I would polish the external also
Everything arrive ok and I got the new board in and started re-assembling the loop making the necessary changes for new tube positions and ofc, changed that red logo!
Everything installed and time for bleeding, leak checking:
To do list
Spray the Crucial SSD White - Done
Sleeve the PCIE extension cables - X
Logo for SSD - X
Replace red fan mount pads - X
I changed the LEDS for the 3x Thermaltake Riing 12 fans (much quicker than spraying a new set of fans) and Thermaltake are sending me out a new set of blue mounting pads as the the red is quite the eye sore!
My Ryzen chips seems pretty good, 4.0Ghz @ 1.35V so I ran some early benchmarks and as expected:
a) My ram won't go above 2133mhz as it isn't Samsung B Die
b) Performance is behind the 4790K in gaming - Mainly due to the ram being gimped.
Deus EX DX 11 - 41.3 FPS
Deus EX DX 12 - 42.2 FPS
Gears Of War 4 - 76.5 FPS !!
GTA V
Pass 0, 16.625481, 133.778503, 66.664261
Pass 1, 41.975506, 133.763519, 67.613251
Pass 2, 58.717888, 116.847809, 78.435951
Pass 3, 39.712051, 137.252487, 85.089516
Pass 4, 31.004484, 132.872253, 73.063103
Rise of the Tomb Raider DX 11 - 87.34 FPS
Rise of the Tomb Raider DX 12 - 88.81FPS
The Division DX 11 - 82.1 FPS
The Division DX 12 - 89.4 FPS
__________________
Old 11th Apr 2017, 02:57   #3
stealth80
Supermodder
New bios today released by Gigabyte, helped my ram speeds a chunk, 2666mhz now, however after some quick testing my CPU seems unstable above 3.85ghz now < 1.4v - ill test some more, a quick rerun of RotTR DX12 sees an increase of 92.4 FPS from 88.1, so a nice bios indeed, just need to get the CPU back to 4 Ghz and retest whilst waiting for the last few pieces to complete the build prior to final pictures
__________________
Old 11th Apr 2017, 15:13   #4
stealth80
Supermodder
Got the SSD finished today and started on the PCIE cable extension sleeving
__________________
Old 12th Apr 2017, 01:14   #5
stealth80
Supermodder
Ok so another 12 hours spent on this (ok 3 hours gaming, and 1.5 hours driving/shopping to pick up some damn ATX pins)
It's almost complete, just need the fan mounts from Thermaltake, so time for the glamour shots!
New logo applied
SSD painted and pun logo applied!
The completed sleeving and painted Pump
LCD layout changed
Gskill RGB Ram
__________________
Old 12th Apr 2017, 06:55   #6
23RO_UK
Hasta Mañana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
That looks proper tidy
Nice one fella
(I'll be joining you in the Ryzen Club in the next few weeks )
23RO_UK is offline   Reply With Quote
Old 12th Apr 2017, 11:56   #7
stealth80
Supermodder
Nice one fella
Thanks, that sleeving was a bitch to do haha!
The platform is better than I expected for such a new architecture especially with regards to stability. Bios updates are give and go, I was stuck at 2133mhz and the chip could hit 4.0 ghz @ 1.35v now I got 2666mhz ram but CPU seems to cap at 3.8ghz - I need to play more.
Just be ready for teething issues!
__________________
Old 21st Apr 2017, 13:10   #8
stealth80
Supermodder
Thermaltake kindly sent me the replacement fan pads, so I guess it's complete !
Thanks for viewing!
__________________
Old 21st Apr 2017, 13:28   #9
atc95
I have the upgrade bug!
atc95's Avatar
atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.
Looks impressive, blue and white is a much better colour scheme than the usual black and red! Have you got a link for that screen and do you use rainmeter to set up the layout? Interested in adding something similar to my mod.
__________________
PC: It's a work in progress, but isn't it always...
Check us out on twitch at https://www.twitch.tv/digitalbacongaming
atc95 is offline   Reply With Quote
Old 21st Apr 2017, 13:38   #10
stealth80
Supermodder
Thanks!
Ok the screen I bought from ebay along with a plastic surround, I think it was like £44 all in:
Like this:
http://www.ebay.co.uk/itm/For-Banana...YAAOSwwpdW77NX
and the frame/case
http://www.ebay.co.uk/itm/Raspberry-...wAAOSwZVlXtY9x
The software used is Aida64 - specifically the sensor panel, I used online guides to figure out how to import images and set up the sensors, but after 10 mins or so you will have it worked out.
Hope this helps
__________________
Old 21st Apr 2017, 14:01   #11
atc95
atc95's Avatar
Originally Posted by stealth80 View Post
Thanks!
Like this:
and the frame/case
Hope this helps
Thanks, will do some research.
__________________
Old 3rd May 2017, 23:37   #12
stealth80
Supermodder
Ok so I hated that Enermax fan in the back of the case and decided at add another 120mm XSPC AX radiator to the rear mount using another EK Varder. And after reseating my ram I can finally run it at 2933mhz up from 2666mhz - Gotta love these Ryzen bugs! (still not 3200mhz!)
Rise of the Tomb Raider bench up a little more again, every little helps
Ill got some more "completed pictures" up over the coming days (work tomorrow)
__________________
Old 13th May 2017, 16:19   #13
stealth80
Supermodder
So I initially fitted an XSPC 120mm ax rad to the rear, but it looked bulky and I didn't like the tube routing, so I decided to change it for a 120mm Alphacool crossflow which needed to be spray white (duh lol)
__________________
Old 21st May 2017, 12:32   #14
stealth80
Supermodder
Seemed my GPU temps were getting high (63C) which was due to a combination of a few things : Block needed reseating and cleaning and case airflow. So I reseated the block and completely stripped out the build to add a front intake fan. At the same time I painted the inside of the case white:
In the next picture you can see why it isn't located centrally on the front - due to tube routing
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
