Build Advice I7 Self build or prebuilt
Discussion in 'Hardware' started by Jokaz, 17 May 2009.
  1. Jokaz
    Jokaz What's a Dremel?
    24 Apr 2009
    Hi all,
    Apologies for yet another I7 build thread.
    I am currently looking at a new PC - but do I build it myself or buy?
    If I build I will go for the following components, with Windows 7 as the OS.
    Any comments on build?
    CPU - Intel Core i7 920
    Memory - 6GB (3x2GB) CorsairXMS3, DDR3 PC3-10666
    Motherboard - Gigabyte GA-EX58-UD3R OR Asus P6T SE
    Harddrive - 1TB Samsung HD103UJ Spinpoint
    PSU - 750W TX Corsair PSU
    Case - Akasa Omega - Black Aluminum Case
    Cooling - Noctua NH-U12P
    Graphics - 1GB Sapphire HD4890
    Opitcal Drive - Samsung SH-S223Q/BEBN
    Monitor - 24" Samsung SM2433BW
    Keyboard - Logitech G11 Gaming Keyboard
    Mouse - Logitech G5 Laser Gaming Mouse
    Total(inc VAT) £1,341.56 (£1116 excluding the monitor)
    However, Pcspecialist could build a similar spec system for £1139 which includes 1 year warrenty (the case would be Coolermaster 900).
    So which is better pre-built or home made?
    I know with home made I will be getting all of the componenets I want. However,buying prebuilt means at least I have someone else to blame if things go wrong.
    Any advice would be greatly appreciated.
  2. bagman
    bagman Minimodder
    18 Apr 2009
    home made definatly but there are a few things i would change
    graphics 275 GTX
    cooling titan fenrir
    motherboard Gigabyte GA-EX58-UD3R
    other wise very good choises
  3. IDave
    IDave What's a Dremel?
    23 Apr 2009
    I was faced with this same choice last month (not for an i7 though, as my budget was lower). I couldn't find a prebuilt one that came in below my budget and had all the components I wanted. A lot of them had cheap RAM or cheap PSUs, or you had to pay lots more for a decent case.
    Ended up deciding I could build it myself so I read up on the do's and don't and asked for a bit of advice on a few forums and built it myself.
    Ok there's no overall warranty, but each of the components has a warranty. By the time you have learned to build it yourself, you will understand how to identify which component is at fault if you have a problem, and if you are stuck just get on the forum and ask for help.
    How technically minded are you? If you would consider yourself to be even of average intelligence then build it yourself. It's just like a big lego set really, you just follow the instructions and the feeling of satisfaction afterwards is great. Much better than just opening a box, unwrapping your computer and plugging it in.
    After having built my first computer I don't think i'd ever buy a pre-built one ever again.
    :thumb:
  4. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    + 1 for the motherboard go for the gigabyte EX58 UD3R, i have one and it has no problem overclocking to 4.2Ghz. Dont go for pre-built system build it yourself its more enjoyable and you learn alot
  5. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    That seems to be the best way to go at the moment.
  6. crowmanuk
    crowmanuk It's just for games ... honest !
    17 May 2009
    Went through a very similar thought process with a similar budget a month or so ago. I went for the self build option as my theory was that I would change bits over time. Was great fun and a real learning exercise ... also means I know every cable and screw.
    Went for a similar spec to you but went with an Antec 1200 case - I also went for a 4890 and it has been brill. The motherboard I went for was the Gigabyte GA-EX58-UD5 which was / is a dream to work with. Also went for a Be Quiet Dark Power Pro PSU which I would recomend.
    Build yourself - you'll enjoy it.
  7. Jokaz
    24 Apr 2009
    Thanks for the input all.
    Just a question regarding the PSU - would the systems run fine with a 650W Be Quiet Dark Power PSU or should I be looking at 750W or more - I don't plan on overclocking. I did notice on the Pcspecialist site it said that the power requirements for the system was around 450W and the PSU I had chosen was a bit of overkill
    Thanks again
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    650W will be fine. :)
    trig likes this.
  9. trig
    trig god's little mistake
    10 Aug 2006
    +1
  10. crowmanuk
    17 May 2009
    Have found the Be Quiet Dark Power Pro 650W to be a great unit. Comes with an excellent cable selection too. Highly recommended.
  11. Jokaz
    24 Apr 2009
    Think I will go for the Be Quiet Dark Power Pro 650W PSU and the Noctua NH-U12P for cooling as its quieter than the titan fenrir although it pushes my costs up. Will order all my bits soon - thanks again all
