can this be right? the game says my computer is only med spec but this is my current setup gtx 580 intel i5 sandy bridge 8g ram running on windows 7 64 bit also when i installed the game it says i only have 4g off ram
Just use custom settings, set everything to max except ubersampling Assuming its a normal res' your using (nothing extraordinary )
what he said ^ i have everything maxed no problem with my rig with just ubersampling off, would like to see some comparasants (cant spell that lol) side by side with that on and off if anyone has the time to see where all that power goes
Really!? I was just complaining in another thread that for me, with your exact settings, was bordering on unplayable for me. I wonder if there really is something wrong with my card? What's everyones' GPU utilisation & GPU memory usage while playing? Perhaps I should mention I play at 1920 * 1080 TSB
im playing at 1920x1200 dude, so higher rez, i think you may have a problem somewhere... dont know my FPS on them settings, but its smooth as butter. dunno on mem usage but GPU utilization is goes from 96 to 98%
Mine's turned all the way up aside from ubersampling and I get about 40-60 fps. I may turn ubersampling and see what it does
thx all got everything on apart from ubersampling and getting between 45-60 fps would it be a good idea to delete any off the 3d vision files?
