Electronics Alphanumeric LCD - Plugged to USB > LPT Converter?
Discussion in 'Modding' started by Skylined, 11 Jul 2004.
  1. Skylined
    Skylined Minimodder
    3 May 2003
    I'm getting a LCD with the classic Hitachi controller to plug it to the parallel port.
    I have my 7 segment display plugged to my parallel port right now and I would like to use both displays at the same time, the LCD and 7SD.
    I've seen some USB to Parallel Port converters, but I have no idea how they work and if I'm going to be able to either plug the LCD or the 7SD to it.
    Can anybody tell me if this works?
    Otherwise I'll have to get a PCI card with a LPT. :)
  2. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Yes it should work.
    But you might find it un-nesicerry.
    Depending on the software you use of course.
    But you could have a latch, on one of the control pins, that determines if you are talking to the 7seg display, or the LCD.
  3. Skylined
    Skylined Minimodder
    3 May 2003
    I think that wouldn't be easy.
    And I don't know anything about programming. :)
  4. code81
    code81 What's a Dremel?
    12 Mar 2004
  5. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
