Electronics laptop lcd modded into computer
Discussion in 'Modding' started by henson0115, 1 Aug 2004.
  1. henson0115
    henson0115 Banned
    16 Apr 2004
    hi i havnt quite done it yet but i was wondering if anyone has any clue how to do this noob at the subject the lcd screen is from a dell latitude 433 thanks shane
  2. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    This question gets asked all the time.
    :search:
  3. infernis
    infernis What's a Dremel?
    5 Jan 2003
    Most bare LCD modules take a digital input, usually an LVDS type signal. Unfortunately, your videocard only offers VGA or DVI outputs. Either source will need to be converted to LVDS using an appropriate controller chip and board. Controller chips and their boards are tailored to match the signal characteristics of certain LCD module families, so it's difficult to source a so-called "universal" controller board. Controller boards are usually expensive, running in the $150-200 range, so they're not for everybody.
    Also, any LCD worth its salt is backlit, usually with the help of a cold cathode fluorescent backlight. This requires an inverter board to provide the necessary AC voltage and frequency.
    Finally, you'll need a power supply to power your LCD, for standalone use at least. This usually is in the 12 volt, 2-3 amp range, but as the power is delivered by the controller board, you'll need to conform to the requirements of the specific controller board. If it's a nice number like 12 volts, you could connect the LCD straight to your PC's power supply.
    So you need a controller board, an inverter board, and some sort of power supply. It's an expensive, tedious, but rewarding task. Just make sure you know as much as you can before putting down any money.
    Your first task, if you choose to do so, will be to strip off the plastic trim to expose the bare LCD. It'll be framed by a thin metal enclosure if you do it right. Now look for the manufacturer and part number of the LCD module, and report back.
  4. henson0115
    henson0115 Banned
    16 Apr 2004
    m-ke55-32ntk
    ver.a5/lot.422
    no.012250
    p-5505a
    4111-oh
  5. infernis
    5 Jan 2003
    Nothing. Who's the manufacturer?
  6. henson0115
    henson0115 Banned
    16 Apr 2004
    doesnt say but found another number 0RB4BI0IA0499-BC IF THAT HELPS THANKS ALOT SHANE
