overclocking a64 3000 woes
Discussion in 'Hardware' started by tamffc, 30 May 2005.
  1. tamffc
    tamffc What's a Dremel?
    5 Oct 2003
    to cut a long story short,overclocked my cpu,got as far as 220htt and now have a totally corrupted 200gb sata drive.
  2. bengaskell
    bengaskell Banned
    4 Nov 2003
    :duh:
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Helpful....
    Ok, what settings were you using at 220? Did you drop the LDT to 4? Were you running 1:1? vcore, vdimm etc :)
  4. bengaskell
    bengaskell Banned
    4 Nov 2003
    Sorry I couldnt help but no one had posted a reply and I helped him get attention with my slick cool humour. I appologise for the post. Hope you get it workin, I had same problem with laptop sata drive. Had to get data recovered.
    bg
    :thumb:
  5. Krikkit
    21 Jan 2003
    That sucks dude - the lesson here is to use a secondary drive for an OC boot drive ;)
  6. Austin
    Austin Minimodder
    16 Jul 2004
    :grr: Was it nVidia based? Even the 'almighty' nForce4 only tend to lock 2 of the supplied SATA so if you push HT beyond 10% in one of those unlocked ports expect corruption. I'm unsure of how VIA and ATi fit in regarding SATA locking.
  7. tamffc
    5 Oct 2003
    yeah its a nforce 4 board,(just read that this is a common fault with the raid controller used)i was running vcore at 1.45v.
    my sata drive was only a storage drive(luckily most things were backed up but not all)
    it also stopped my comp from booting prom my pata drive?but hadnt corrupted any data on it.
    anyway after a reinstall i now seem to have it stable at 205htt,memdivider at 5.4 vdimm 2.6ldt 4x
  8. TMM
    TMM Modder
    12 Jan 2004
    If you push it too far you can still mess up windows even if your pci/sata is locked
    Usually happens when your ram is unstable.
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Were you doing this with clockgen? Interesting thing of note with near all NF4 boards - locks DO NOT work at 200 HTT. 201 works like a treat however.
  10. tamffc
    5 Oct 2003
    no i was overclocking in the bios.
