Notebooks £500 - £650 Budget Laptop
Discussion in 'Hardware' started by Modsbywoz, 10 Dec 2012.
  1. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Staffs, Just Outside Mordor.
    Just about to order a laptop for myself for work.
    Could anyone recommend me one? As it will have to be used for a few years I would like the build quality to be quite good. Either that or good service repairs.
    Laptop to have the following criteria.
    1. Needs a decent screen (1080p preffered)
    2. Nothing over 16inch (Some laptops are too big)
    3. Will be used for Web Development / Graphic Design.
    4. Needs to cope with light Photoshop Work.
    5. Will be running a light apache development server.
    Any ideas or experience with different makes? I'm currently stuck with either Dell or Sony VIAO.
    Cheers!
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    South East England
  3. minimad127
    minimad127 CPC Refugee
    24 Apr 2009
    Near Canterbury
    using the Asus above as a base spec
    maybe something based around this
    http://www.pcspecialist.co.uk/notebooks/genesisIV/
    dropping in similar spec to the asus above brings it to £650 ish but allows for more user customisation, such as dropping the GT635 but popping a core i7 in, or dropping the blu ray and getting a i7 and the GT635,
    a bit more power in the graphics department i would look at this one
    http://www.pcspecialist.co.uk/notebooks/enigmaIV/
    as dropping the blu ray player can get your a GT650 instead of the GT635 etc etc
    have a play and you can get some very interesting combinations
  4. katty1166
    katty1166 Banned
    22 Nov 2012
    A decent screen will cost a little more
    How about Lenovo Y580 15.6-inch with 1920 x 1080 Display Resolution
    It features NVIDIA GeForce GT660M with 2GB VRAM, and it with the 3rd Generation Intel Core i7 3630QM Processor with Intel Turbo Boost Technology up to 3.3 GHz.
    Check details if interested
