Scratch Build – In Progress 【MSI PRO MOD - S3】"YAZI" - Venator Class Star Destroyer V1 - FINISHED!!
Discussion in 'Project Logs' started by ASPHIAX, 19 Oct 2015.
  1. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks! I think the guys over at lulzbot will be happy to hear that ;-)
    Cant wait to get some time and properly experimant with it.
    HD GLASS, Aluminum Powder, Wood, Carbon, its all within range with this machine!
  2. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
    "You know what the fun part about 3D printing is?
    There's always something sweet waiting for you when you wake up."
    This is my favorite part as well. Love to have my Printrbot Simple Metal work while I sleep.
    Impressive build! :thumb:
  3. Cheapskate
    13 May 2007
    Zooming in and singing "BUM bububu BUM" already.:D
    On a side note: :lol: You have a radiator bin!
    Unless your printer is a dud, then it's like having a cat. -Waking up and finding a turd has been prepared for you.
  4. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Genius !
  5. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Thanks for the info' .... I'll have to investigate !
  6. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    No problem man! Check out their forum, got lots of opensource upgrades and tools ;-)
  7. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    The final loop has been found!
    Inside the case I will be mounting several 3d printed PETG coolant tube guiders and supports, VGA and I/O space and some decoration.
    You know when you have spent to much time in 3D when you start sketching it only also.
    Only 300 left to solder Sander ... Pfew ...
  8. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    First light ...
    Lightning !
  9. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
  10. Cheapskate
    13 May 2007
    The flat flat panels obviously print up quick. I bet you are already sizing up the kitchen table for your next project.:D
  11. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Hahaha, no I actually have a wall that may needs doing ..
  12. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    I am sorry for the lack of updates from my side
    There has been so much work done in the last few days but I need every minute I can get ..
    Because the YAZI will be at the International CES 2016 in Las Vegas.
    Here is the transport box for it ..
  13. Cheapskate
    13 May 2007
    Arrows, dude! :lol:
  14. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Geeeezzz , we was happy we got it home. Father in law miscalculated.
  15. The_Crapman
    5 Dec 2011
    God dam it man, pictures! We need pictures!
  16. Cheapskate
    13 May 2007
    -Not strapping it to the roof for wind tunnel testing. :nono:
  17. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    "YAZI" - Venator Class Star Destroyer The BIG finale part 1
    Ok so here is the big finale (wel part 1 of it at least)
    Due to the fact that MSI asked if they could showcase the YAZI at the International CES 2016 in Las Vegas the whole time table changed.
    I am very strict op planning, its the only way to get stuff done fast, but this was ridiculous. The call came in about a week before the cutting of the aluminum, hence the reason why Pascal and I worked untill 3 am to get it sorted.
    I proved not to be the last day I was up untill late !
    Here we go:
    Started with the always nice smelling epoxy work on the tower
    Then it was off to the dirty room for paint, got a nice anthracit paint. The pictures dont do it justice, its darker and less brown.
    Quick test fitting
    And finally the last of the about 300 holes!
    With the holes done, it was time for the greeble basecoat.
    The detail just popps out with this coat.
    And a quick test fitting, sure looks good in aluminum
    But thats not the plan. So gave it a healthy coat
    And then a good black matte paintjob
    With the black coat on I could finally start to epoxy the greebles onto the side hull
    Meanwhile : That was the first box of 8 kg PLA, onto the next one!
    Decision time, should i paint the greebles also in the anthracit coat?
    So happy with the anthracit, it really has excellent licht action properties
    I love doing test sessions lol
    Houston we have a problem! That was the last of the 50 meters of fiberoptic cabling ...
    Waiting for the fiber, I put myself to the next design challenge the motherboard tray and I/O backwall.
    I just love waking up to fresh new custom parts
    Ahh the joys of fiberoptic cabling. It wants to go in any way but the way you want it ..
    But ... the force is strong ...
    Poor mans glue clamp, well actually you can buy a lot of clamps for this grand 1200 watt powerhouse by Thermaltake!
    Also installed the rest of the lighting for the tower.
    Someone asked my what happened to my old build the USS EURISKO.
    Well its standing next to my work pc acting as a side table lol
    This looks just too cool not to share
    Working 12 to 16 hours a day takes it toll ..
    Installed the fans back into their housing. These are the original fans for the build 2 years ago. Try finding a decent 92mm fan these days ...
    I discovered a neat trick while glueing the 3D printed PLA. You can cut into just one or 2 of the layers and bend it precisely
    Me working the very last of the fibers, will be glad when this part is over ..
    The hull needed a little old fashioned styrene love
    I wish I still had my workshop, space runs out quick with my builds!
    Me working the epoxy ..
    Darth practising his one-liners ..
    And there you have it, the result of the small ModMarathon ...
    Post Project Carnage ..
    And that was it for part 1 , stay tuned for part 2 and 3!
    Have a good one!
  18. Icelander
    Icelander Minimodder
    3 Mar 2015
    hope you make it before CES man.
  19. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Well the YAZI shipped out 2 days ago and I have sent a lot of tools with it, to be able to repair any damage from transport but also add a bunch of enhancements like cannons, greeble strips and maybe if i can find the time some lasers !
    Part 2 is coming up ..
  20. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    So here is part II
    I managed to get the hull painted two hours before the scheduled pickup for the CES.
    Quick dry before the next layer. The weather was helping a lot!
    Got something very special planned for the radgrills.
    3D printed red HDGlass radgrills!
    The front in this picture is missing due to change in plans at the last minute.
    Love this picture, she looks so dark and grimey here !
    I could not build the loop due to possible issues at customs.
    This must be one of my favorite views. Will look sweet with the loop installed.
    And finally with the lights on !!
    Had to dismantle all the hardware inside so again no issues at customs.
    Made sure that it was very well strapped down and covered up ..
    Bye bye baby!
    And there you have it. From cradle to grave a complete log of how I built this first version!
    Hope you enjoyed watching as much as I enjoyed building her!
    On to the next one!
    Regards
    Sander aka ASPHIAX
