A+ Launch New Cupid Range Cases
Discussion in 'Aplus Chassis' started by Nathan@Nanopoint, 3 Mar 2009.
Thread Status:
Not open for further replies.
  1. Nathan@Nanopoint
    Nathan@Nanopoint Ctrl Alt Del
    2 Feb 2009
    A+ Cases have announced the release of three new computer chassis which are being aimed at the ITX market. The range is named Cupid with the three models having the names Cupid 1,2 and 3. They have a modern look while also being outstandingly constructed computer chassis with a beautifully mirrored front panel finish.
    The high-quality construction of the chassis and good engineering allows for easy assembly & the cases have soft edges for optimum installation safety.
    All three include a built in 56 in 1 card reader, 2x USB 2.0 & audio interfaces hidden under a front panel & Aluminum scratch-proof wrinkle texture coating on side panels.
    Cupid 1 is only 185 x 70 x 255mm in size and features 1x 5.25" bay for optical drives and 1x 2.5" bay for a hard or floppy disk drive to be installed.
    Cupid 2 is a wider chassis but maintains a slim profile at 300 x 65 x 290mm and features 1x 5.25" bay for optical drives & 1x 3.5" bay for a hard disk drive. Both come with external efficient power supply's with the option of 60W or 90W.
    Cupid 3 is 220 x 129 x 323mm and will house 1x 5.25" optical drive and 2x 3.5" for hard disk drives. The unit is slightly bulkier but gives more space if desired for installation and hard disk space but will require a micro ATX PSU which is not included.
    All three models will be available early March with the RRPs ranging from
    £49.99 to £59.99 respectively.
Thread Status:
