Modding a little n00b help :)
Discussion in 'Modding' started by RatFace, 2 Sep 2003.
  1. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    *almost faints with shock*
    A :dremel: is a very versitile tool which can cut, polish, sand and do multiple other things..
    an example
    (unless you were being sarcastic?)
  2. bladesilver
    bladesilver What's a Dremel?
    6 Sep 2003
    its a rotary tool with little various bits that go on it, saw blades, drills, etc. basically extremely high rpm so it can cut things without making a big mess about it.
    www.harborfreight.com search for rotary
  3. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Yes ,I use MSN Messenger. Same mail adress.
