Hardware Aerocool Dead Silence Cube Review
Discussion in 'Article Discussion' started by Meanmotion, 30 Dec 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Seems strange to review a case designed to be quiet without some measurement of how silent it is, other than saying it keeps noise levels low.
    I know it can be hard to measure noise levels, but with more cases being designed for silent PC enthusiasts it would be nice to know if the sacrifice of higher temperatures equals noticeably lower noise.
  3. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    Corky: When mine has arrived later this week and I've built my system into it, I'll do some noise checks and post them up.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My system is running, but I can't do any noise checks due to the 48TB file server & 1.5kW UPS in the same room drowning it out.
    As for temps, Asus' auto-overclocking software thinks the system in my sig is happy & stable @ 3.9GHz
    The review doesn't mention the colour choices available with this case:-
    Black chassis / White panels (as shown in the review)
    Black chassis / Red panels (for Asus users?)
    Black chassis / Black panels
    Black chassis / Orange panels (for Zotac users?)
    White chassis / White panels (mine)
    All available either with or without a window.
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    It's not really feasible to do accurate noise testing in the environment we work in.
    The colours are mentioned in the specifications list.
  6. GiantKiwi
    6 Jan 2011
    Luckily, because of the place I work, I have access to sound proofed recording booth's to do the audio test in :)
  7. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Funnily enough I just completed a build in one of these yesterday.
    It really is very quiet.
    One thing I would point out though is I was using a not massive BeQuiet 650w PSU with modular cables and it was a super tight fit. I had to remove the 2.5" bay temporarily to slide it in from the reverse side, then refit the 2.5" bay.
    This bay is clearly not meant to be removed and required much swearing and removing of all panels first, including the base, which was cunningly held in by invisible screws which were hidden beneath self adhesive feet.
    My point being - check your PSU length first!
  8. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    How easy is it to remove the HDD cage at the front? It could bake a great M-ITX case with a that out and a 200mm rad in the front.
  9. vdbswong
    vdbswong It's a Hedgehod
    23 Apr 2009
  10. Corky42
    30 Oct 2012
    Cant you all stop shouting at each other for more than 5 min :D
    On a more serious note, i get that testing for noise may not be possible. Its just a shame that a case can lose points for bad cooling and not get a chance to gain them back, if you are willing to put up with super fast (noisy) fans you can pretty much make any case great at cooling.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You have to remove the base as do_it_anyway says above.
  12. do_it_anyway
    24 Apr 2009
    Actually, the front 3.5" cage is part of the motherboard tray and can't be removed.
    The 2.5" cage at the back, alongside the PSU is the removable one.
  13. David
    7 Apr 2009
    Are you sure about that?
    Looks to me like the drive cage is screwed to the mobo tray, and only the left hand wall of the drive cage isn't removable; as it forms the upright for the tray.
    [edit] It even mentions it in the review:
    YEHBABY likes this.
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I'm sure. I've done it (then put it back as I'm using a mATX mobo). See what Spreadie says above me. :rolleyes:
    You have to peel off the sticky feet to access 3 hidden screws holding the plastic base on, to access the screws holding the bottom of each drive bay.
  15. iggy
    iggy Minimodder
    24 Jun 2002
    ITS NOT A CUBE!
    YEHBABY likes this.
  16. David
    7 Apr 2009
    NEITHER ARE ICE CUBES!
    YEHBABY likes this.
  17. Gareth Halfacree
    4 Dec 2007
    But do you have access to high-grade sound meter equipment? The biggest problem in doing sound testing of a case like this is that the equipment to do it - not the room to do it in, which can be nothing more than a broom cupboard lined with egg cartons - is really effin' expensive.
    Here, for example, is the sort of thing you might buy to do sound testing. It's under £15, so what's the problem? Oh, wait... It doesn't work below 50dB - and the manufacturer's peak noise level for the fans in this case is 21.5dBA. For products sold as 'silent,' it's not unheard of for the rated noise level to drop below 10dBA - especially when the fan is inside a case, as with this particular review - so a 50dB floor ain't going to cut it.
    Okay, let's spend more. £113 gets you this - but wait, that only goes down to 32dB. Ooh, this one at £190 has a PC interface - damnit, 35dB. Okay... This one's nearly £270, surely it... What, 30dB? Right, sort by Price - Highest... Ah, this is the most expensive Amazon sells at £582. Now we're talki... 70dB minimum?! Oh, it's for workplace health and safety surveys. Oh, well, I guess that makes sense...
    You know what? Let's forget Amazon. Let's go straight to a manufacturer. Here, Extech do a specialist low-level meter... Oh, 26dB? And it's discontinued? Bah. Right, Norsonic has a specialist 'sound analyser' in the Nor140. Still, it's doable - with a normal microphone, it can measure down to 12dB - although its self-noise level is 26dB, meaning that anything below that level is likely not going to be measured terribly accurately. Also, I can't seem to find a price - meaning it's likely one of those "if you have to ask, you can't afford it" cases. There's a UK company renting 'em for £24 a day, though, which ain't too bad.
    TL;DR: A sound-proof room is by no means the most difficult part of measuring case noise.
  18. David
    7 Apr 2009
    So the Sound Meter App for the iPhone won't suffice then? :p :lol:
  19. GiantKiwi
    6 Jan 2011
    I'll have a talk with head of Film, he was wandering round a few weeks back with what looked like a rather expensive dB meter checking the noise leakage into an unfinished booth. ;)
  20. Corky42
    30 Oct 2012
    To right it gets expensive, but TBH if i wanted to test and measure low dBA i would use a mic system such as the PS9200KIT along with a spectrum analyser such as SpectraPLUS. But even then you are looking at $2000 for the mic and another $1000+ for the software.
    Is that the manufactures noise level you are quoting there ? as even a silent fan such as the Scythe GlideStream cant get bellow 10dBA even when undervolted to run at only 550RPM.
Tags: Add Tags
