Hardware AMD Radeon RX 580 CrossFire in Prey at 3,440 x 1,440
Discussion in 'Article Discussion' started by Dogbert666, 25 May 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    London, England
  2. Vault-Tec
    30 Aug 2015
    In Rainbows
    Wow, Crossfire actually worked :D
  3. Mr_Mistoffelees
    26 Aug 2014
    Waiting For The Worms, Behind The Wall
    I would still prefer to spend my money on a single, much more powerful card and not have to contend with poor, or non-existent, support for multiple cards in many games.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Praise the mince pies, Bit-tech finally acknowledges the aspect ratio of the gods:clap:
  5. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    London
    I have just upgraded to 3440 x 1440 and it really is something else! Would v much recommend it, although the support in games can sometimes be a bit iffy at the moment.
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Bristol, UK
    CF works quite regularly, though I had negligible benefit from a 3rd card except for one or two games, 2 cards was the sweet spot.
    Only had a couple of games in my collection that didn't work, tended to be stuff that was fast single card anyway like Assetto Corsa, newer DX12 titles seems to have shafted Multi GPU though.
    But really, full 4k or more, none of this half measure ultrawide :p ;)
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    I'd rather see the resolution go up on ultrawides than go back to a narrow aspect ratio.
  8. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    lincolnshire, uk
    Agreed!
    I'm currently using an LG34UC98, sitting in front of any none ultrawide monitor now is painful! I'd love to upgrade to the 38UC99 but I just can't justify the extra cost atm.
  9. DbD
    DbD Minimodder
    13 Dec 2007
    Really poor!!! - this is just an advert.
    Testing crossfire is fine, but don't just do it in the the one game AMD told you to do it with. Do it with a selection of games. Test frame times as they frequently suffer with multi-card and xfire in particular has done very badly in the past. Show single card alternatives (e.g. a 1070 or 1080).
    It doesn't take a genius to guess if they tell you to only test one game then that might just be because all the other games out there don't work as well. So much for unbiased independent journalism...
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    And it is openly declared as such at the very start of it.
  11. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I've said it before, but I'd rather see these advertorials posted in a separate section rather than in with reviews and other non-commissioned pieces. Just blurs the lines a bit imo, even with the disclaimer at the start.
  12. adidan
    25 Mar 2009
    Outside your house.
    There is a huge disclaimer at the start, people don't have to read it. Chill out everyone.
  13. Omnislip
    Omnislip Minimodder
    31 May 2011
    I can see where you're coming from, but I can't imagine bit-tech really makes a killing from advertising. As long as these articles remain well signposted, I'm happy if the site keeps running!
  14. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Hull
    Keep doing what you have to do to bring money into the business
  15. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    East of Ipswich
    For balance Bit really should run a couple of 1060s in sli ...oh wait!
  16. Pete J
    Pete J Employed scum
    28 Sep 2009
    Blighty
    I know that Anfield's addressed this, but learn to read, man. I'd forgive you if it was only mentioned in passing halfway through the article, but it is mentioned in italics at the start AND the end of the article.
    Unfortunately, it's not as though review sites swim in money. They need help and this is a side effect.
  17. spolsh
    spolsh Multimodder
    4 Feb 2012
    Workington
    Yep, bit have been totally above board about it, and have taken the time to do the crossfire review. I'm confident they haven't massaged the results, they just ran their tests and reported on them. And as fingerbob69 (can only really remember fingermouse from fingerbobs) said, they can always run a really, really short 1060 SLI review too.
  18. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Swansea, Wales, UK
    1060s don't support SLI
  19. Gareth Halfacree
    4 Dec 2007
    Bradford, UK
  20. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    I would hope now you have these set-up in crossfire you will be doing a proper review on the benefit/drawbacks and giving us a proper recommendation on whether Crossfire RX580's are actually a serious option for more than just prey?
Tags: Add Tags
