Development An easy one for you VBS nutters
Discussion in 'Software' started by Shirty, 25 Sep 2015.
  1. Shirty
    18 Apr 1982
    Really simple one here: I have the following code to strip out small files in a folder:
    Code:
    Dim strPath
    Dim lngSize
    Dim fso
    Dim fold
    Dim files
    Dim file
    lngSize = 12
    strPath = "C:\FOLDER"
    Set fso = CreateObject("scripting.filesystemobject")
    Set fold = fso.GetFolder(strPath)
    Set files = fold.files
    For Each file In files
        If file.Size <= lngSize Then file.Delete True
    Next
    My question is: If I want to add in another check so that it only deletes files under 12 bytes that begin with shirty_is_sexy what do I need to do to my script?
    Internet handjob cookie may be available for the first answer. I am not a coder so I don't know jack about this sort of stuff.
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    This might work:
    Code:
        If StrComp(Left(file.Name, Len("shirty_is_sexy")),"shirty_is_sexy") = 0) Then
    Next
  3. Shirty
    18 Apr 1982
    Looks good, but returns an error:
    Line: 17
    Char:78
    Error: Expected 'Then'
    Code: 800A03F9
    Source: Microsoft VBScript compilation error
    Any thoughts?
  4. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    remove the bracket after the 0 in the second line (of that code snippet)...?
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    I could write you that as a function in powershell if that helps?
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    This should do what you want
    Code:
    $path = "C:\folder"
    $bytes = "12"
    $namematch = "shirty_is_sexy*"
    Get-ChildItem $path | ? {$_.PSIsContainer -eq $false -and $_.length -lt $bytes -and $_.name -like $namematch} | % Remove-Item -Confirm:$false -Force
    You can test it without deleting anything by using WhatIf like so:
  7. Flibblebot
    19 Apr 2005
    Oops, yes that should work - or add an open bracket in front of StrComp.
  8. Shirty
    18 Apr 1982
    Thanks for your input chaps, will report back on Monday!
