Windows annoying Lag when opening My network
Discussion in 'Software' started by yakyb, 31 Aug 2010.
  1. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    okay a minor annoyance
    but my network is fast as hell, sustained 90MB/s copies over it and everything is fine and dandy
    however whenever i open my network (windows 7) it takes about 15 seconds for my network computers to show up.
    normally i just access my server using '\\home' which has no problem whatsoever, but on some windows (open folderdialog) its just not possible and you have to wait for all network comps to be found
    surely there is a service somewhere that is able to keep a map of networked computers and keep it regularly updated
    anyone know what it is or whether its something that needs to be broadcast or listened
    or could this be a dns issue?
    cheers
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Surrey, UK
    Well there are myriad things to consider when accessing network shares, such as AntiVirus software, DNS configuration, the NTFS volume (security descriptors & indexes) setup, etc.
    Also, do you have multiple switches/routers on the network? Do you find that the slowness occurs only when having to traverse switches/routers?
