Modding Anodising an Intel stock heatsink
Discussion in 'Modding' started by k4p84, 24 Aug 2015.
  1. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    Hi all,
    Here we have a little mod to the intel stock cooler. I know many do not hold the stock cooler with much regard but I have always felt that as a stock heatsink it is nice and compact and quiet for most of the installer base.
    So we will be anodising the aluminium part of the heatsink black.
    Let's go through a few anodising info.
    It is an aluminium oxide layer on the surface of the aluminium to protect the more reactive bare aluminium.
    There are different types of anodising to give your parts more desirable features like resistance to mechanical / chemical / temperature as well as a method to colourise parts.
    Here we will just be doing cosmetic anodising as I want to turn the part black.
    So the heatsink needs disassembling and cleaning. I passed it through an ultrasonic cleaner to help remove any dirt as the cooler has been used.
    Now I will not have pictures of the parts going through the tanks as there are other customers parts going through too.
    A quick overview of the process from here :
    • Jigging - mount parts on a jig so that they can be moved through the different tanks without needing to be handled directly and so that current can be passed through more pieces more efficiently. These can be simple as a stiff wire to custom make jigs for repeat customer parts or difficult to hold due to size or weight.[/*]
    • Cleaning - any material that prevents the chemicals from contacting the aluminium will prevent the process occurring on that area. This can be beneficial if you need a grounding surface for example (aluminium oxide is non conductive on the whole) but if you have grease / dirt on the surface you will end up with a blemish.[/*]
    • Anodising - here the anodic layer is put down, the parts size will increase by a few microns. The anodic layer is porous, think a metal sponge.[/*]
    • Dying - if you are clear anodising you skip straight to sealing (spoilers... :) ) otherwise parts are dipped into a dye that enters the porous surface. To get different shades you dip the parts for different times, maybe 5 seconds for very light to a few minutes for stronger colours. Fun fact you can't dye white as the white pigment is too large to fit into the porous surface, if you can make a smaller white pigment you will be rich !![/*]
    • Sealing - generally done in a chemical bath but can also be achieved with boiling water you close the surface of the anodic layer sealing in the colour(s)[/*]
    • Drying - leave the parts jigged up in a hot room to dry off all the water[/*]
    In between each tank you must thoroughly rinse the parts so you do not contaminate the following tank or to stop the dying process for example.
    Now the process does change depending on the properties that you would like to bring out and the materials been used. You may need to use different chemicals, times, temperatures and voltages but as an overview that should give you an idea of what goes on.
    Always let your parts sit for 24 hours to let the sealing go off fully and then clean them off, general purpose kitchen cleaners work great with a nice towel. (do not use anything bleach based it will damage the layer)
    Now to reassemble the heatsink and take some more pictures.
    I may revisit this the put a sticker over the stock intel on and replace all the wiring making the whole unit a stealth cooler.
    A few myths / more info :
    • It will cover the base metal surface finish. If you anodise a polished part you get a polished finish, anodise a media blasted part you get a dust finish. If you have imperfections in your surface finish they are not hidden so finishing off your metal surface well is important. You can brighten the surface finish giving you from a matte chalk board effect to a very slight sheen, this would be mainly done on dust / sandblasted finishes.[/*]
    • It is sticky. If you handle a part and it feels sticky or it takes fingerprints that part was not sealed well. The best way to explain this is that the anodic layer is porous prior to sealing, this is how colour is held in the layer. Parts are chemically sealed but can also be heat sealed so if you have parts you want to seal boil them in water for 10 minutes.You can anodise at home. Sure you can but the chemicals used and given off are not very pleasant as well as disposal of said chemicals needs to be done safely.[/*]
    • You can re anodise parts. You can but you need to remove the previous anodic layer. This is eroded away chemically so the parts do get very slightly smaller each time you do this. In practice (depending on tolerances etc) you could anodise a part 2-3 times before things like threads get to sloppy for example.[/*]
    • The process will dissolve other metals. Very true, you can anodise aluminium and titanium but other metals will be dissolved and if done too often will result in needing to clean out your tanks more often. You can mask over parts that can not be removed, press fitted threaded inserts for example. Chemically resistant tapes as well as rubber based fluids can be used to mask them off from the chemicals.[/*]
    • You can remove anodising with oven cleaner. True again, strips it off but is not very precise.[/*]
    So there we go we have a lovely black heatsink. I did not paint the parts as getting a good finish in the intricate surface would be difficult and I did not want to put a layer of paint over the metal to insulate it as I do not want the effectiveness of the heatsink to be reduced.
    Many other effects can be achieved as you can see from another piece I did that week for a friend ..
    If you have any questions etc post up and I will try to help out.
    Regards
    Ed
  2. Arboreal
    21 Jan 2011
    Really interesting post, I did some basic anodising and dyeing at school in chemistry club - I've ALWAYS liked coloured aluminium, so great to see a bog standard Intel Heatsink stealthed!
    I have had vinyl cut circles done to cover case fan and heatsink fan labels.
    A friend with a sign shop cuts them on offcut vinyl, it works well.
    Great timing, I was thinking about anodising on aluminium case accents last week, my local place is very expensive, minimum charge over £70 for a single piece about 30x20mm to be anodised and dyed black.
  3. k4p84
    20 Aug 2008
    Hey,
    I have plotter but no black vinyl in atm.
    £70, ouch, if you are UK based you can send it my way if you would like.
    Regards
    Ed
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I didn't think it was possible to make an Intel cooler look good, but you have pulled it off! I agree that the reference coolers are never as bad as everyone makes out (so long as no overclocking is happening) and they do the job just fine.
  5. Arboreal
    21 Jan 2011
    Ed, thanks for the offer. I may have some things to work on.
    My friend is sure to have black, let me know what size discs, and I'll get some run up - I only have white and could do with a black one for an Intel cooler.
    BTW, do you do bead/glass blasting on ali to make it satin?
  6. k4p84
    20 Aug 2008
    Hey,
    I just got some vinyl ordered so it looks like I will be finishing the mod of completely stealthily....
    Surface finishes :
    Hydroblasting - glass beads propelled by water. this gives my preferred finish for a 'dust' finish.
    Two grades of media blasting, gives a rougher finish than hydroblasting that I am moving away from.
    Brushed - only on flat surfaces
    Polished - a real PITA as ali been soft you can burn it so this is outsourced to stop me going grey(er)...
    Regards
    Ed
  7. Arboreal
    21 Jan 2011
    Brilliant, that's good to know what's available.
    I used to have an ali bodied car, and polishing was a 'mare, as you got black gunge everywhere.
    When I'm ready to start playing with ali (re shelling part of a case to make it lighter, I'll start a new thread.
    Anyway, the black intel cooler is way better than stock.
  8. theshadow2001
    3 May 2012
    It's possibly the first time an Intel stock cooler has ever actually been cool.
  9. k4p84
    20 Aug 2008
    Hey all,
    Thanks for the comments :)
    Sooo I decided I could not leave this little mod in it's current state, this weekend we shall see the final vision...
    Replacement stealth cabling and plug
    Stealth sticker
    I may even break out the studio lights to take some better pictures of the finished project.
    Regards
    Ed
  10. k4p84
    20 Aug 2008
    Right then, let's finish this !!
    First off those rainbow cables had to go. I did snip the cable of a Corsair PWM fan here as come hell or high water I could not find 26 gauge 4 conductor black sheathed ribbon cable, if anyone does know of a decent source in the UK please post up.
    Remove the very shiny sticker, head over to the solder station and de-solder the original cables and solder in the new ones .
    Now we need to make a black sticker to cover the whole top of the cooler and just because we can let's cover up the cable channel too.
    Simply place some paper over the area and do the same as if one was brass rubbing to create an outline of the design that is needed. Scan the outline and import the image into your software of choice, draw out the design and plot that file on some lovely matte black vinyl.
    tah dah !!
    As you can see I added some tabs to the cable channel portion so I could wrap them around so that any cable strain would not pull the sticker straight off.
    Once applied we have a beautiful stealthed out Intel cooler.
    So there we have one stealth cooler that simply looks far better than it did at the start.......... but wait........................
    Dare I say it looked a little too plain...
    A little head scratching later and I was torn between adding the CPU model number to the top of the cooler or adding the intel logo...
    The logo won the mental battle and after cutting it out of some 'intel blue' vinyl behold the masterpiece in all it's glory !!
    Intel marketing people if you see this, this is what you should be sending out, make it happen :)
    Here endeth the mod.
    If anyone does need some help with anodising or vinyl cutting for either direct application or for painting masking please let me know I am happy to assist in any way I can.
    Regards
    Ed
