Case Mod - In Progress Antec P380 CeBIT 2015 - march 29th 2015
Discussion in 'Project Logs' started by Hukkel, 16 Feb 2015.
  1. Hukkel
    Hukkel James' minion
    20 Dec 2012
    The orange in the sleeving indeed is way more bright than the orange UV plexiglass. I have orange plexiglass that is also bright orange, but it is not UV plexi. Should I remove the orange wires and just go with black and white in the sleeving?
    Hi Mark, the covers are made using 1 mm thick aluminium that has a brushed blask finish. I think it is annodised. A C Ryan used to sell this. Then the logos were engraved in it using a laser cutter / engraver.
    I hope this helps.
  2. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Have to agree, the orange looks out of place
    - but then again, if you go only black/white, it might blend in with the background too much?
    Other than that, this mods looks really good.
    It has a certain "Lego Blacktron" feel to it - a color combination that i think looks really cool!
  3. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Antec P380 CeBIT 2015 - march 9th 2015
    Yes i thought so, just wanted to be sure ;-) thanks man, about the sleeving, i would remove orange and use a neutral colour like grey which will looks good with black and white combo
  4. Hukkel
    20 Dec 2012
    Thanks again for the comments guys! :thumb:
    Right now I remade the stock Antec PCI-E cables. Shortened them to fit exactly and made it so each connector on the PSU leads to 1 connector on the GPU. No splits wires. All omnomnomnom :rock:
    I am going to sleeve these now. They all need to be done before I mount the PSU cover and all its tubing connected to it. Then I cannot reach anything anymore.
  5. Vognen
    Vognen Minimodder
    2 Oct 2013
    Maybe go with white as the main colour and then with a few black wires in between? Your motherboard is white aswell, so I'd reckon it'd fit really nice together with the motherboard
  6. Hukkel
    20 Dec 2012
    I have been thinking about it. But time is reeeeeally short and I hope when the UV lights are on the difference will be less there. I don't know. Time currently is the big problem. Only a few more days left.
  7. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    Nice work mate
    GPU wiring reminds me on my arc mini
    Can you keep anything of this mod after the CeBit ? (PN is ok)
  8. Hukkel
    20 Dec 2012
    I have a hole in the midplate for the cables. Running them straight up will save me so much wire cluster.
    The project will travel with Antec from show to show to LAN party to LAN party for about 18 months. After this it will return to me. So yeah I get to keep it, but only after a long period. What is left of it that is hahaha. At these shows people steal like crazy, maybe I will get an empty case with a puddle of coolant in it xD
  9. saxovtsmike
    12 Aug 2008
    Whatever is left in 18 Month, it will be worth the wait and stress at the moment.
    Gratulations to that.
    even if it´s stripped out and smacked, a couple of fans and radiators will hopefully be left
  10. Hukkel
    20 Dec 2012
    Thanks buddy. TBH I am really for the ride here now of having something I created on display at CeBIT on the Antec booth. I can't wait to see it on display with people looking at it. :clap:
    In the end the hardware will be re-usable for another project or sold to fund part of another project. But that is after Antec has had a lot of fun with it and has taken it around Germany for promoting purposes.
  11. Hukkel
    20 Dec 2012
    The loop is finished. Time for leaktesting. I also added various extra details such as the orange 2nd layer snake head, the MSI dragonheads on the backplates, the Antec P380 decal, etc. I feel like it is all coming together now.
    It is minutes to midnight now. Tomorrow it will be in the car with me going to Hannover. Going to leaktest now and finish up on some small things.
    :dremel:
  12. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Looks very nice Hukkel! Cant wait to see it filled and up! :)
  13. Hukkel
    20 Dec 2012
    Thank you for your kind words :)
    I took a few photos of the finished product with its UV lighting on. The coolant has only a tiny bit of blue in it (dye) but a lot of transparent UV dye. It kind of makes it look like the system is filled with ghosts smile-emoticon
    Now some sleep, tomorrow packing it and driving to Hannover.
    Goodnight!
  14. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    That looks sweet man, the UV yellow kills it :)
  15. montymole
    montymole Rigid Tubist
    24 May 2010
    looking good dude :)
  16. Hukkel
    20 Dec 2012
    Thanks guys, I am now packing and leaving in 20.
    Hopefully I will get some nice shots there as well.
  17. Cheapskate
    13 May 2007
    Looks great. Hope you have fun.:D
  18. Hukkel
    20 Dec 2012
    Thanks man! And yeah I did :)
    The Antec crew was super friendly!
    Me and my buddy Jens.
    Better photos next week. They promissed to make some. :clap:
  19. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
  20. Hukkel
    20 Dec 2012
    Thanks baby!
