Modding Any ideas on how to...
Discussion in 'Modding' started by Reevey, 22 Apr 2004.
  1. Reevey
    Reevey What's a Dremel?
    14 Apr 2004
    Fit a FX5900 Ultra (Gainward 1600XP) into a Shuttle?
    I think Im right in thinking that it's too big to fit in a shuttle.
    Any ideas?
  2. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    erm cut a hole in the side panel? and have the big fan/HS sitting out the case?
    then make a box around it made of mesh :thumb:
  3. Lithium
    Lithium super spunk
    26 Jul 2002
    Emmm push it into your AGP slot. :rolleyes: If the case is too small then you are screwed or you could always mod it :dremel:
  4. Reevey
    14 Apr 2004
    Yeah well I know that it wont fit with the case on, just looking for ideas on how to do the case really. should have said that soz :/
  5. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    Umm... bubble window?
  6. livelife46290
    livelife46290 What's a Dremel?
    19 Sep 2003
    Storm trooper has got it, just take a piece of plexi, heat it then bubble it outwards, then drill some holes into it for cooling of the card and your all set!
