Hardware Asus O!Play Air HDP-R3 Media Player Review
Discussion in 'Article Discussion' started by Lizard, 24 Mar 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    whyy does everyone continually say the HTPC is dieing when clearly looking at all the forums around more and more people are trying to build one
    Not only are they much more customizable than this but the interface / Metadata is much better
    a lot of work still needs to go into the automation of media ripping i.e. DVD to MKV/ISO on insert of the disc and meta data grabbed automatically and stored in a tidy location
    but this will come over time (also BD is still an issue on most HTPC software)
    whitlst i agree that this may be easier you still need to know how to put media onto an esata drive and if you can do that you should be able to configure an HTPC
  3. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Well it seems that A.C. Ryan's offering is considerably more expensive, though the Western Digital media actually seems fairly priced and remarkably good value overall. For me Asus products have always either been amazingly brilliant or a complete failure and this one goes in to the failure bin for me.
  4. Guest-16
    Guest-16 Guest
    http://www.scan.co.uk/Product.aspx?WebProductID=1132287 Try that one. It's also very good, but we have yet to write a review.
  5. p3n
    p3n What's a Dremel?
    31 Jan 2002
    ion nettop + xbmc is practically the same price, these products feel like a con Oo
  6. wyx087
    15 Aug 2007
    i was looking at that after reading this review, it seems to be identical to the non-mini Bit-tech reviewed, just without the hard drive bay and 40mm fan.
    really tempted for my parent's TV, it's a fanless mini solution that seems to work very well.
    Ion nettop costs more than £200, these costs around £100 and includes a remote.
  7. p3n
    31 Jan 2002
    Nope. http://www.ebuyer.com/product/167153
  8. wyx087
    15 Aug 2007
    oh, okay, i was thinking Pinetrail machines, rather than the original Atom machines. thanks.
  9. mi1ez
    mi1ez Modder
    11 Jun 2009
    I've said it before, and I'll say it again. When they sort out a media streamer that does spotify and last.fm (and has a decent quality audio output) I'm in, not before.
  10. Guest-16
    Guest-16 Guest
  11. poldo
    poldo What's a Dremel?
    31 Jul 2009
    Ugh, have you guys heard of Xtreamer? I have one and I find it much better than the one you just reviewed.
    http://www.xtreamer.net/xtreamer/overview.aspx
    Its cheaper than WD's offering and it has the ability to be equipped with an internal 2.5-inch hard drive.
  12. p3n
    31 Jan 2002
    xbmc linux has had hardware accel. for donkies years...
  13. kornedbeefy
    kornedbeefy What's a Dremel?
    1 Sep 2009
    I looked and looked for the perfect media player to fit my needs. They all seem to have some fault or another so I went with the Acer Revo 3610 mini-HTPC instead and extremely happy I did. Sure it cost $300 (U.S.) but it does everything I need without worrying what formats it supports.
    www.pauljroberts.com/acer-aspire-revo-3610-atom-ion-330-review
    Windows 7 came with mine.
  14. plagio
    plagio What's a Dremel?
    26 May 2004
    I have an xtreamer as well. It's just a fantastic piece of hardware. Never had problem with it and I read enthusiastic reviews everywhere.
    Bit-tech review was the only one with thumbs down.
    Strange reviews at bit-tech lately.
  15. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Loved the failstastic xD
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    WOW aside from the main interface, everything else interface wise is exactly like Patriots Box Office, although the Box Office supports ISO playback which was added with a simple update so I would suspect the same is possible with the O!Play.
    I like the addition of weather and online content, as well as gigabit and wireless N, I dont know why most of the others are 10/100. So if ASUS updates this to have ISO playback then I think it would be ideal.
  17. jonmcc33
    jonmcc33 What's a Dremel?
    31 Jan 2007
    You won't see a decent Atom Ion nettop with HDMI and S/PDIF and a remote for this type of price. In most cases XBMC requires some configuration. I have a Western Digital WDTV and I just plug it in and turn it on. It plays every MKV I toss at it.
  18. p3n
    31 Jan 2002
    All of them have HDMI (with audio), S/PDIF is ancient.
  19. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I have my xbox 360 connected to my main PC via ethernet and just watch everything on that..its fine.
  20. vanu
    vanu What's a Dremel?
    19 May 2009
    Really? So if you have a set of speakers with decoders, Z-5500 for example, how would you connect them via HDMI? :)
Tags: Add Tags
