Hardware Asus ROG Strix Z270G Gaming Review
Discussion in 'Article Discussion' started by Dogbert666, 30 Jan 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Vault-Tec
    30 Aug 2015
    That's a lot of bread for a board but I gotta admit I am sitting here in a puddle of drool.
    I really do love these new Strix boards. So elegant and classy.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Sitting here with a 4770K and a Maximus VI Gene, so this mobo is likely to be my next one.
  4. rollo
    rollo Modder
    16 May 2008
    Mobo costs have been around this point for anything labled ( Asus Rog gaming) for a while now.
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, this is about the going rate for this tier of motherboard. Still too dear imo but it's not as if this is a big price hike over the previous generation. It's also not quite as eye-watering as the £250+ Z270 efforts we've seen recently.
  6. Plastic_Manc
    Plastic_Manc Minimodder
    25 Apr 2009
    Aye, price point is what I'd expect for the "entry level" ROG. They make quality motherboards do Asus but can't for the life of me think why I'd bother to move from my 4790k and Ranger at present.
    Why do board makers always factor in their onboard soundcard effort though, so many own a dedicated card that it would be nice to have the option of buying the stripped out version for a few quid less.
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    MicroATX = the most pointless form factor out there.
  8. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Totally disagree - it allows you to go smaller than ATX without going to the extreme of mini ITX. I was going to base my X99 build on mATX but ultimately decided to go for ATX because I could get it cheaper.
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Three and four way SLI are dead (crossfire soon to follow).
    Consumer Pci-e SSDs have been stomped into the ground by the M.2 offerings.
    Soundcards have vanished from 99.9% of PCs.
    There really aren't that many scenarios left where you need anything bigger than MATX.
  10. GeorgeK
    18 Sep 2010
    Same - I think that my next build will probably be MicroATX as that way I can have what I want (1 GPU and 1 PCIE soundcard) without having tons of leftover space. Should allow for a smaller case than what I currently have too.
  11. Combatus
    16 Feb 2009
    I'd argue there's nothing extreme about mini-ITX either. It's smaller, but if you don't need more than one GPU then what are you losing? You still get dual-channel memory, decent on-board audio, at least one M.2 port and as Anfield says...
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    For me personally, uATX is all I'll ever need, which makes ATX pointless :D That said, I'm not sure that I'd bother with uATX when mITX offers almost everything that uATX does but in a smaller footprint. The only reason to go with uATX is to be able to use PCIE cards, but given how well-specced most mITX boards are now, I can't think of a reason for me to require add-in cards.
    Obviously there are plenty of people out there who do need expansion slots, so mITX isn't suitable. Horses for courses and all that :)
  13. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Maybe not the form-factor in and of itself, but many completed mini-ITX builds are most definitely extremes in that they are "as compact as possible". My Thermalright cooler is 171mm tall... too big even for some ATX cases, and certainly not on any mini-ITX builds I've seen!
    So it's kind of a given that if you're buying a mini-ITX board, you'll also be buying a mini-ITX case and that's where the constraints are to be found.
    Right now, the sweet spot for me is an appropriately wide ATX case without drive bays. Much smaller footprint but plenty space for drives and such.
Tags: Add Tags
