Modding Asus TUF Armorsuit Z77 by Paul Tan
Discussion in 'Article Discussion' started by brumgrunt, 11 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. mhadina
    mhadina What's a Dremel?
    29 Aug 2009
    Great !
  3. faxiij
    faxiij Minimodder
    25 Jan 2011
    not bad, not bad at all. now i'd like to see what you can do with more time than two weeks, mr tan! :))
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    page 3 and 4 have some of the same images
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    wauw :O!
  6. Combatus
    16 Feb 2009
    Thanks docodine, sorted that now!
  7. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    Man If only I had those skills...
  8. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    I'm trying to get my chin off the ground... great work, as i never seen in years...
    I loved everything in your project, just unbelievable.
    Congratulations on the great work, I just hope you continue making more mods. :)
  9. mi1ez
    mi1ez Modder
    11 Jun 2009
    That's pretty amazing! 850W seems overkill though, no?
  10. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    I haven't been to the Projects Logs forum in a while an.. WOAH! That thing is cool. ^^
  11. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
  12. Parge
    16 Jul 2010
    Spectacular construction and build quality, but I just don't like the design on this one. No slight meant against the creator, its just not my cup of tea (think it might be the GPU all the way out there on the side).
    Well done nonetheless :)
  13. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Inspired by Tron no doubt... :)
  14. paultan
    paultan R E V E N T O N
    22 Jan 2010
    THank you so much Bit-tech for allowing me to share this story :) The pleasure will always be mine to work with you guys. :) I'm happy to see it here. Really really appreaciate everything! Mod On!
  15. mi1ez
    mi1ez Modder
    11 Jun 2009
    That's not the GPU, it uses integrated. The outboard is watercooling.
  16. Nictron
    Nictron Minimodder
    16 Feb 2007
    Awesome, I Like!
  17. Xir
    Xir Modder
    26 Apr 2006
    The Sabertooth Z77 hasn't been tested here has it?
    Is it worth buying over the Gene V?
  18. bullseye
    bullseye Who dares wins
    28 Apr 2009
    Nice work. But when I first checked out the pic's, I thought it looked like a souped up printer.
    But top marks for originality.
  19. PaulC2K
    PaulC2K PC Master Race
    14 Apr 2004
    Out of interest, was there no room underneath, alongside the PSU, for a GPU on a riser cable or something? Thats the one issue i have with it really, if there was an ability to place a couple of PCI-E cards under the mobo, as an option to increase its appeal then i think it'd make a great design.
    I get this is a design requirement you were given, and a GPU was out of bounds from the get-go, im just wondering if that could have been possible, maybe with slightly wider dimensions or something, or am i overseeing the required room for any storage media?
    Its not quite my personal dream case, but its certainly very attractive and unique, and i'd still love to have one sat on my desk. Great job.
  20. Ljs
    Ljs Modder
    4 Sep 2009
    In my opinion, this is one of the best mods I have seen on this forum. Very original and finished to a very high standard.
    Kudos.
Tags: Add Tags
