Cooling Asus X370 Pro Fan Headers
Discussion in 'Hardware' started by GeorgeK, 18 May 2017.
  1. GeorgeK
    18 Sep 2010
    Ashford, Kent
    This board has the following fan headers
    CPU_FAN
    CPU_OPT
    AIO_PUMP
    CHA_FAN1
    CHA_FAN2
    W_PUMP+
    All are 4 pin headers and from what I can tell they're all rated for 1A except the W_PUMP+ which is rated for 3A. Can I just plug the CPU fan into the CPU_FAN header and then plug a regular chassis fan into the other 5? The case I will be using has 5 fans and it'd be tidier than using splitters.
    Cheers
    GK
  2. RedFlames
    23 Apr 2009
    The wrong quantum reality
    IIRC it should work, might cause a few headaches if want to use any fan control gubbinz though.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Besaid
    You'll be fine, they are just labelled so you have a way of identifying what fan is plugged where when you're adjusting fan curves/profiles... Providing you actually remember after you've finished building the thing and put the side panels back on :p
  4. GeorgeK
    18 Sep 2010
    Ashford, Kent
    haha - I have the same problem with my Z87 sabertooth. I got round it by setting all to minimum except 1, peering through the side panel and then ramping one up to max to see which started spinning faster! Now that I've set my fan profiles in the Asus software I can't for the life of me remember which is which again though... Cheers for the help both
