CPU Athlon 7850 Upgrade. RAM and GPU upgrade.
Discussion in 'Hardware' started by Kronos, 19 Dec 2012.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Looking for advise to give someone else a reasonable upgrade from the Athlon 7850 and Asus M3N72-D and also looking to upgrade from 2 x 9500 GPU's all for the princely sum of $400 (£250). Oh and at least double the RAM. He currently has 3 x Kingston HyperX 1GB (PC2 8500).
    I no nothing of AMD hence I am seeking advice here. Over to you folks.
  2. The_Crapman
    5 Dec 2011
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
  4. The_Crapman
    5 Dec 2011
    i presumed they were in the US since you quoted a dollar budget?
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Yep I think so.
  6. davvy76
    davvy76 Minimodder
    18 Jul 2004
    I'd ditch the am2 stuff and go am3+, at least it leaves you with an upgrade path of sorts plus gives you ddr3 ram
    http://www.newegg.com/Product/Produ...80&IsNodeId=1&bop=And&Order=PRICE&PageSize=20
    Just make sure it supports 125w cpu's eg:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813135314 ECS A960M-M2
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814134131ECS NGTX560TI-1GPI-F1
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820104277Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3
    $374.96
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks for taking the time to do look out the above.
  8. The_Crapman
    5 Dec 2011
    good spot davvy. I'd go with that over my suggestion.
