News Battlefield 3 capped to 30FPS on PS3
Discussion in 'Article Discussion' started by CardJoe, 20 Jun 2011.
  1. Donteatmypanda
    Donteatmypanda What's a Dremel?
    2 Mar 2011
    Nowt wrong with 30fps in my opinion. I'd rather play locked at 30fps than unlocked with dips in framerate. Still DICE need the fps lower than 60fps to fit realtime global illumination and destruction in there. The Battlefield 3 frostbite 2 engine looks all the more ambitious when compared to the invisible walls of Call of Duty: World at War.
    Edit: excellent little article on frame rates:
    http://www.100fps.com/how_many_frames_can_humans_see.htm
    nice article!
  2. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Sheffield
    Good, I'm glad someone understood me :)
    My explanation was going to be this:
    If you are shooting video at 24 frames per second using a "shutter speed" of 1/24 seconds you are in effect capturing all of the information about what goes on during the time you are shooting. If you have a camera that can do 240 frames per second at a shutter speed of 1/240 you're just subdividing that information into separate frames. Layer ten of them together and you have exactly the same image as one of the 24fps frames - a fast moving object will be blurry.
    Any shutter speed faster than 1/24 reduces the motion blur in each frame, cutting out information and eventually introducing a noticeable "staccato" effect. Go look on Youtube for videos taken by people with newfangled video-capable DSLRs without knowing what they're doing - 24fps and a shutter speed of 1/1000 begins to look remarkably like a laggy video game.
    A frame from a video game essentially has an infinitely fast shutter speed. It's information from a single instant in time, given out as many times per second as your graphics card can manage. You need a heck of a lot of frames per second just to equal the amount of information your brain receives from properly shot 24fps video.
    Still, it varies from person to person. I am perfectly happy with 60fps, and to be honest I'm happy with 30 as well in most games, though it is a noticeable step down.
  3. dangerman1337
    dangerman1337 Minimodder
    2 Sep 2010
    After looking at the PS3 footage (well best for youtube you could get) and this being on 720P and 30FPS (assuming locked) is good. IIRC most AAA titles on the HD twins are 720P and 30FPS. Though I have seen some people in comments saying as summed up "lol weak DICE lol goin to MW3 suck it haterz".
  4. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    i hate to disagree with you but i cant play most games at 30fps
    they even make some people feel sick cause they are usually so jerky at that framerate
  5. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Godalming, near Guildford
    I meant in games where there is no motion blur. 24fps is fine for TV, as all the information within each 24th of a second is captured on the film. You don't miss anything, it's just merged into a single frame.
    Games, without motion blur, is a whole other story. You render a wheel spinning at 60rps at 60fps in a game, and it will look static, as each rotation exists between the frames.
  6. pingu666
    pingu666 What's a Dremel?
    24 May 2010
    so 1/4th of what a modern gaming pc can output (120hz monitor)
    a faptastic rig would be 120hz tripplescreen, 57xx x1080 and in 3d too :)
  7. Elton
    23 Jan 2009
    California
    I'll only take a 3D screen if it's not in a TN panel. That aside, this isn't that surprising, most games on consoles are usually 30fps.
  8. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Yes, I am sorry but the whole Bit-tech / Custom PC "25 fps min is fine" assertion is BS.
    Rather than join in the technical discussions I will just say this...
    I find it very noticeable in most games if I am running at 25FPS - and it basically sucks arse.
  9. PerfectDark
    PerfectDark What's a Dremel?
    20 Jun 2011
    Battlefield 3 is will look much better than MW3 on PC.... But the console versions of the 2 games may be the opposite.... maybe....
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Why do you care? Shitty consoles get shitty game performance. Boohoo. If you want the cutting edge, if you want BF3 64 player at true high definition with AA, then get a decent PC. If you want to play games on a mass produced piece of crap for the cheapest possible price, then buy a console.
  11. PerfectDark
    20 Jun 2011
    To make it work in 720p with 2X-AA they will have to decrease graphics quality at a point that i doupt it will look beautiful like PC... even 4 meters away from Screen you will see the difference with PC....
    Something else i see strange is that they said it's not 1080p because of graphics quality.... like hell they would make it 1080p not even GOD could on a console.... Why should i believe it will even be 720p???
  12. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Copenhagen, Denmark
    Jesus Christ people. It's a question of whether you find 30 fps acceptable or not. It's a personal preference. Don't get all worked up over it.
  13. E_Spaghetti
    E_Spaghetti What's a Dremel?
    19 Apr 2009
    Arkansauce - USA
    What is PS3?
  14. wiak
    wiak What's a Dremel?
    9 Apr 2006
    PC version will allways be best
    why? you can run it at ANY resolution and framerate (unless they have capped it)
    and run it on the highest settings with highest AA
  15. Deders
    Deders Modder
    14 Nov 2010
    Here and there, mostly there
    It depends on the game and the engine it runs on, some games can be seamlessly smooth if they maintain above 25fps, others do seem smoother at 60.
  16. SexyHyde
    SexyHyde Minimodder
    24 Jul 2009
    i've found sat on my sofa around 8ft away from a large screen tv 30fps is fine. on my pc sat in front of my monitor i need about 40fps, prefer 60fps and cant really tell much difference any higher.
  17. Crunch77
    Crunch77 What's a Dremel?
    13 Nov 2007
    Denmark
    X360
    More than likely.
  18. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Bavaria
    ...Who the **** cares?
    Buy it on PC and have a proper BF3 experience.
  19. kenco_uk
    28 Nov 2003
    Hurst Green, Halesowen, UK
    Does anyone know if a PC demo is on the books?
  20. Dwarfer
    Dwarfer What's a Dremel?
    30 Mar 2011
    An open BETA is due out in September.
Tags: Add Tags
