Networks Best Cheap Modem
Discussion in 'Hardware' started by cookie! nom nom, 6 Mar 2023.
  1. cookie! nom nom
    cookie! nom nom Minimodder
    27 Apr 2012
    Hay guys,
    I am looking to upgrade from my nowtv router to some a little better, As you can tell from me being with nowtv I'm a cheapskate so looking to upgrade on a budget. I'm currently living in a mid size two bed so hopefully range wont be a issue. I've found a few on Amazon I'm interested but to be honest they are very limited on reviews off amazon. Has anyone experienced the following? And if not what would you recommend i go with?
  2. kenco_uk
    28 Nov 2003
    I've only had TPLink stuff so can only really offer a viewpoint of their kit - it's pretty darn good. Easy to set up and it just sits there doing its thing.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Mercusys is a subsidiary of TP-Link, their budget offering I think. So should still be decent. I'd choose TP-link as well as their stuff is generally rock solid and easy to setup.
  4. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    I recently bought a Mercusys mesh system which has been working great. No experience with that router but I can rep their wireless gear in general.
  5. hughwi
    hughwi Minimodder
    23 Dec 2003
    Have you considered going second hand? there are loads of good TP Link options going cheap on various market places, I would personally look to try and pickup a cheap mesh pair - something like the Deco?
