Scratch Build – In Progress BF 4 M.A.V. Remote [Final Pics]
Discussion in 'Project Logs' started by Ironknocker, 27 Dec 2014.
  1. Ironknocker
    Ironknocker Minimodder
    4 May 2014
    After the housing is finished I put the board times into the case.
    Fits perfect.
    Then we continued with metal details. Above the display the trapezoid, right and left on the sides of the "caps" (I think that's something to be seen in the game bad) and down Windows.
    So in the original:
    And here the reaction in the metal.
    That's it for today
  2. Ironknocker
    4 May 2014
    It continued with a few more details .
    Laterally are still a few openings come in and slots for the Satus LEDs at the top above the display
    That's it for today:rock:
  3. Ironknocker
    4 May 2014
    It went on.
    First I sanded all times so I can see if I still need filling .
    The bumps are so minimal that everything would disappear under the filler.
    Here is the size comparison when I have the remote in your hand .
    Then I have the board installed in the housing , the mount for the screws from the lid welded , drilled and threaded filed the cutouts for the Micro USB and USB dual port .
    Loarding folds and the double plug fits perfectly.
    Finally, I 've made ​​the plexiglass window for the cover.
    That's it for today
  4. Cheapskate
    13 May 2007
    I like that you made it smaller than the game version. You still have tons of room to work with, but it's much tidier.
  5. BootSector
    BootSector What's a Dremel?
    25 Dec 2014
    Very interesting, subbed. I like very much when something is being made of metal, with bending and welding. Sometimes I get tired of “life in plastic”.
  6. Ironknocker
    4 May 2014
    Thanks Guys,
    @Cheapskate: i think it very near at the original size. But i have no exact dimensions of the original remote. There really is difficult to assess the player 's hand size.
    Mini update:
    Now the rear and side windows was their turn
    and the slot for SD card
    Then I have drawn the keypad with CAD. Are small.
    Now I 'm thinking whether I make the buttons made ​​of aluminum or polystyrene.
    Polystyrene is faster Alu looks better.
  7. colinmcr
    colinmcr What's a Dremel?
    1 Jul 2014
    Awesome work, love the concept and you defo have some metalworking skills :D
  8. Ironknocker
    4 May 2014
    thx
    Next Update:
    Have made the keys from 2mm aluminum . Despite my sausage fingers it worked out well .
    But first we went to the substructure of the keypad.
    For this I used the other cover of the external housing and cut pointing to size.
    Next, I make two Plexiglas strip , so that the keypad fits later still.
    Then I screwed the plate on the plexiglass and additionally fixed with a few drops of superglue.
    Lid on it and test it. Fits so quite well
    The buttons I've actually even put it.
    Now the buttons can be glued on.
    The opening for the buttons in the cover I made an extra bit smaller so I can still adjust the .
    This is what I made ​​in the next step .
    Thus, the keypad is also ready and working.
    In the game, the keys are still green, but I 'll let her ground in aluminum , as is well known, color worn at much use and it looks like **** .
    That's about it again .
  9. Cheapskate
    13 May 2007
    Nice. -No plastic compromises either.:lol:
  10. Ironknocker
    4 May 2014
    Thanks
    Now a little bit of plastic work.:D
    Now i have to work on the optical fibre form the mediashare to the top
    As a leader, are the director always aware of SMDs I have a piece of polystyrene screwed onto the board ( the picture is before the rework / finely grind the polystyrene ) .
    Das sind die Lichtleiter die durch das Plexi geführt sind und mit Kleber fixiert wurden.
    Then i testet it. It work perfect.
    the optic fiber I will then grind after painting the upper stripe in black, to the right length .
    Thats it
  11. Ironknocker
    4 May 2014
    Before it goes with the painting going on , I have made ​​a parking lot for the plugs and adapters.
    Since the M.A.V. Remote via micro USB is loaded I took a 220V power supply from my old smartphone and a little rebuilt .
    First I sanded everything smooth.
    Then I removed two double USB plug the interior.
    This , I then glued to the AC adapter.
    Now I could measure how great must be the new cover and have these made ​​of aluminum.
    Then I welded and smoothed the edges of everything.
    Finally, I have filed the cutouts in the cover for the connector and charging .[​IMG]
    Thus, the sheet metal work has been completed .
    Next, I will prepare to paint everything and then paint everything.
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome sheet metal work. :jawdrop::clap:
    Amazing lil box. :D
  13. Ironknocker
    4 May 2014
    Today's topic.
    Everything in the paint
    Since I have painted the power supply case yesterday I was able to put together already today.
    According to the topic, I have the USB connector thrown in a shell.
    Nice if you have then a few 12.7mm ammunition cartridges lying around.
    So the PSU looks now.
    That's about it again. Next, assembled :rock:
  14. Ironknocker
    4 May 2014
    update:
    After painting I once assembled everything.
    Here are the images
    Next, it goes to the gums
  15. Ironknocker
    4 May 2014
    Mini update.
    The first rubbers are on it .
    Template I made with CAD.
    Cut out I have then with the scissors and the contours I burnt with a hot wire cutter in rubber.
    That's it
  16. Cheapskate
    13 May 2007
    That came out fantastic.:D
  17. Ironknocker
    4 May 2014
    Thx Cheapskate.
    update:
    It went to the corners
    First I cut the corners of rubber
    first fitting
    Then the Rest of corners and glue everything.
    Als nächstes kommtNext comes the display and lighting circuit and rework .
  18. Farsan
    Farsan What's a Dremel?
    1 May 2014
    WOW!! really great modding skills!
    You rule!
    Witing to see how it works :)
  19. Ironknocker
    4 May 2014
    update:
    Today I have been looking after illumination and display.
    First I worked NEN screenshot from the game and printed on film.
    The back I angeschlüffen with 800 grit sandpaper so that I have a good contrast.
    Then I got down to the lights on.
    First, current flow and then additionally LEDs on the Power / Reset solder board.
    The 5V I have branched off with a plug from the main power supply to the SSD.
    Thus , the LEDs only when the SSD is on.
    So it looks like from the inside .
    Then everything assemble and test .
    I like it. What say you?
  20. Ironknocker
    4 May 2014
    For the time being last update.
    The days I have been looking around the edges and filled with color.
    Then I just tried the same times with the wrapping paper.
    AND now there's pre- final Pics
    I have my final exams by the International Welding Specialist at the weekend, I do not know if I even get to it to make better ; )
    Was a great contest and I hope that I can do some other things until Sunday evening to make the not quite like me ..
    Here is the link from the other worklogs of the contest@ We-Mod-It.com
