Storage BIOS settings for a PATA SSD
Discussion in 'Tech Support' started by Xir, 17 Nov 2014.
  1. Xir
    Xir Modder
    26 Apr 2006
    Hi,
    i got a PATA SSD as a gift today, and would like to try and get it to work, as I've just had to resetup my PC anyway.
    What settings would I need in BIOS, is AHCI something SATA specific?
    Best Regards,
    Xir
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    AHCI is Sata specific. I guess with PATA you just need to configure the drive as master or slave. Personally I always use cable select for IDE drives.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I have used some ide ssd dom on various things. Really there is nothing to do in the bios, other than making sure it's detecting the fastest dma/pia mode the drive is capable of. More importantly is to make absolutely sure the partition is mib aligned and not aligned to cylinder as it will create a performance hit which is best to be avoided.
