Scratch Build – Complete Black Silence - passively cooled home theatre PC (COMPLETED+Final Pics)
Discussion in 'Project Logs' started by Bennibo, 27 Dec 2016.
  1. storm-83
    storm-83 Minimodder
    7 Nov 2014
    dang, that's gorgeous!
    although i second the notion that the lights are a bit on the bright side...
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Awesome :thumb:
  3. Bennibo
    Bennibo What's a Dremel?
    22 Oct 2016
    thanks everyone! im really glad you like it! :rock:
    yes, when i took those pics, the brightness was still at 100% and it looks even worse in those pics.
    now i set it to 10% for the top and 20% for the buttom and its bright enough. the difference is because you usually look at the case from a slightly higher position and down on it. that makes the buttom light look darker.
    also i did some temperature testing. i let prime95 (Custom Run + Run FFT in-place) run for little over one hour and the maximum temperature was at 63/60°C for the two cores.
    im very happy with the results, especially because the system will hardly ever be stressed like that.
  4. kim
    kim hardware addict
    10 Jan 2016
    The level of your work places you on the top 10 at least...I am really impressed by this tiny little jewel....awesome
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    You comment about thermal paste, reminds me of my installation in my Streacom case. I did the same thing while trying to juggle getting all the heat pipes in place and then adding the clamps and screws.
    Great work on the case. :clap:
  6. Guest-56605
    Guest-56605 Guest
    If that were commercially available I'd have one parked under the television now!!
    Great concept and design, superbly executed :thumb:
  7. Bennibo
    22 Oct 2016
    thank you once again guys. i really appreciate it!
    i did some more testing and measured the power consumption with different brighness levels for the top/buttom LEDs.
    Windows Idle 0/0%: 16-17 Watt
    Windows Idle 10/20%: 17-19 Watt
    Windows Idle 100/100%: 25-32 Watt
    Not bad for my 4 or 5 year old ivy bridge setup.
    This also means, in my use case the lights need about 2 watts extra. that is less than in expected.
    i hope i will find some time to take some new final pictures within the next few days.
  8. Bennibo
    22 Oct 2016
    i took just took some final pictures for this project.
    it was a pleasure to show you my work and i hope you liked it!
    my new project will be very likely to start this week :)
  9. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
