Build Advice Build Advice & Help
Discussion in 'Hardware' started by kylelnsn, 10 Oct 2014.
  1. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    I am looking to a build a machine for general use, some gaming and photo editing. Possibly some CAD in the future.
    We have around £600-800 for the right machine must include a screen and peripherals and keep costs as low as possible without compromising on quality components and speed/life of the machine.
    Below is a quick parts list, I want to drive down the price a little, are there any better components at less money? SSD is for the OS as this should give a speed boost??? This list is totally up for swapping and changing nothing in stone.
    Any recommendations on a 22" ish screen at sensible money?
    Very much interested in thoughts, ideas and new lists?
    PCPartPicker part list /
    CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£169.98 @ Scan.co.uk)
    Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard (£88.76 @ Scan.co.uk)
    Memory: Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory (£59.90 @ Ebuyer)
    Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive (£55.00 @ Aria PC)
    Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive (£53.94 @ Aria PC)
    Video Card: EVGA GeForce GTX 760 2GB Superclocked ACX Video Card (£159.34 @ Scan.co.uk)
    Power Supply: Corsair Builder 750W 80+ Bronze Certified ATX Power Supply (£59.98 @ Amazon UK)
    Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.09 @ CCL Computers)
    Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) (£69.99 @ Ebuyer)
    Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter (£26.90 @ Aria PC)
    Other: CASE (£26.14)
    Total: £780.02
    Prices include shipping, taxes, and discounts when available
    Thank you
  2. GTIgeneral
    GTIgeneral Minimodder
    31 Jul 2014
    Ive used an Edimax wireless adapter for years with no issues, i don't game online so i dont know what that would be like, but i always max out my connections download speed, you can pick one up on amazon for under £14, that would save you £12.
    You could probably find a cheaper motherboard and knock £20 off, do you plan on overclocking?
  3. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    What about the Gigabyte GX-Z79P-D3 motherboard at Scan - its best part of £30 less, though loses you the option of adding a second GPU later on.
    I'd also say that you don't need a 750W PSU, 500W should be enough for a single GPU system, dropping to the semi-modular 500W version would save you another £10-12.
  4. kylelnsn
    19 Dec 2006
    Excellent, Power supply will go smaller
    Motherboard want to keep some upgradeability.
    But is this a good setup? Anywhere else to drive down cost?
  5. MrTeal
    MrTeal Minimodder
    27 Aug 2010
  6. kylelnsn
    19 Dec 2006
    Sold on the powersupply :)
    How is the setup going to perform?
    Other: G550M Power Supply (£47.50)
    Total: £767.54
  7. kylelnsn
    19 Dec 2006
    No plan to overclock so no. I will check out the wireless card :)
