Features Building a Water-Cooled Battlefield V PC into an Ammo Crate!
Discussion in 'Article Discussion' started by bit-tech, 4 Mar 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Lovely, but not once did you throw a fork at it.
    When using tiny end mills, RPM and feedrates are appreciated. ;) -Ironically, I know a guy that uses the tiny bits for his work. His response to to the feed & speed question is, "Eh, whatever I have it set to."
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    To be fair I think he has a point haha. I used 800mm/min @23krpm for that 0.3mm endmill but it’s nigh on impossible to compare things properly outside of pro-Level machinery. I’ve tried using all the calculations but found there are just too many variables for it to be consistent.
  4. Attila
    Attila still thinking....
    22 Feb 2008
    To be honest the crate doesn't do a lot for me, but I loved the video and the custom water cooling work. Nice work on both Alex.:thumb:
    Maki role likes this.
  5. Maki role
    9 Jan 2012
    Faints
    Going to have some stuff on the way that should hopefully be right up your street!
Tags: Add Tags
