Other Buying a mountain bike
Discussion in 'General' started by techhead, 5 Feb 2017.
  1. techhead
    techhead Minimodder
    17 Jul 2010
    I have been thinking about buying a mountain bike I have £400 to spend and I need some advice. As I have not owned a bike since 1984(a long time ago)
    bikes i have had a good look at
    Scott Aspect 970 2017 Mountain Bike £379.00
    https://www.evanscycles.com/scott-aspect-970-2017-mountain-bike-EV286177
    Cannondale Trail 6 2017 Mountain Bike £499.99
    https://www.evanscycles.com/cannondale-trail-6-2017-mountain-bike-EV284083
    Carrera Vengeance Men's Mountain Bike - £320
    http://www.halfords.com/cycling/bikes/mountain-bikes/carrera-vengeance-mens-mountain-bike-black
    Carrera Vulcan Men's Mountain Bike £370( this is a higher spec)
    http://www.halfords.com/cycling/bikes/mountain-bikes/carrera-vulcan-mens-mountain-bike
    Any help or advice will be greatly appreciated
    thank you
  2. Mr_Mistoffelees
    26 Aug 2014
    Try looking for discounted 2016 bikes, you'll get a better bike for your money if you are happy not to have the latest thing.
    BTW, I bought my first mountain bike in 1984, one of the first in the West Country.
  3. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Of the ones you've listed my preference would be the Cannondale (I'm biased as I have a trigger though)
    It's worth looking at some of the bigger retail stores offerings as they seem to come with better specs than the big name brands whilst also getting great reviews. At this price point I'd be looking for an air sprung fork and hydraulic discs, most of the bikes will have a mix and match drivetrain, but with a gear only shimano deore groupset coming in at around £120 it's a worthwhile upgrade once the stock stuff starts to wear/gets broken.
    Calibre Two.Two V2 £399
    B'TWIN ROCKRIDER 560 £525
    Vitus Bikes Nucleus 275 VR (2017 not available just yet £489.99
    A couple over budget but shows what a bump in price would get you, the 2016 Vitus was thought to be the best bike you could buy for less than £500. It's also worth bearing in mind that you can get some cracking deals on 2016 models, so don't rule that option out.
  4. techhead
    techhead Minimodder
    17 Jul 2010
    Thanks for the reply's I was looking at the Vitus nucleus it has a lot of spec but i will keep looking around thanks again
  5. techhead
    techhead Minimodder
    17 Jul 2010
    Has any one else got ideas for a good mountain bike .I will increases my budget up to £600 for the right bike.
    I do value 13eightyfour suggestions they ware all dam good bikes just not in stock. I would had that Vitus in a heart beat.
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I would always avoid Suntour forks, always seemed to be rubbish when I started biking, my first Saracen had them on and they didn't last long.
    I'd reccomend a Btwin from Decathlon, I've had a Rockrider FR150 for years and it's been great, you seem to get a pretty decent spec on the bikes too for the price.
  7. techhead
    techhead Minimodder
    17 Jul 2010
    That's what I am thinking the low end sun tour are very bad. just been to go out doors and had a look at the Calibre Two. Two a nice little bike. I was going up to Decathlon to look at the Btwin later on
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    BTwins get really good reviews. Well worth considering.
  9. Vault-Tec
    30 Aug 2015
  10. techhead
    techhead Minimodder
    17 Jul 2010
    the BTwins bike they have not my size in stock and the Kona Kahuna Mountain Bike 2016 is a little out of my price range
    but keep the ideas coming
  11. techhead
    techhead Minimodder
    17 Jul 2010
  12. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
  13. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Like all things the recommendation will depend upon your needs and usage.
    • What sort of riding are you planing on? Commuting (asphalt, cement, cobble stones), Maintained trails, Single track, Downhill, etc.
    • What level of usage? Daily, Weekly, Monthly, etc?
    • Storage? Will the bike be left outside, kept in a garage, lockup cage, etc?
    But the most importantly factor is how it feels to ride. You cannot get this from a website.
    Personally I wouldn't buy a bike with out riding it first. I have gone to a store having done all my research thought I knew which bike I wanted then then went for a test ride... The bike didn't have the right fit/feel for me. A completely different cheaper bike with inferior parts felt so much more comfortable (same frame size but with a shorter top tube). A simple decision, better fit/feelings bike, and One can always upgraded the parts. There is more to a bike's fit then just standard measure by frame size.
  14. techhead
    techhead Minimodder
    17 Jul 2010
    The cycle to work scheme does not apply to me as I am a long team carer for my mother(8 long years )
    I am one of these people who as to go the shops and test things touch and what ever else then go home and think about for a long time( it took me 6 months to pick a keyboard).
    No to downhill biking but everything else why not
    shops I have been in
    Evans Liverpool
    Halfords Liverpool
    Go out doors and giant today
  15. veato
    veato I should be working
    15 Jan 2010
    I recently went to Center Parcs and realised my bike is getting on a bit now. Started to look at what I could get quite cheaply and found a Sloope BTX 4.6 Disc 2016 at Evans for £359.99 in my size. Specs looks pretty good for the price (although I'm not sure about those front forks) and with Cycle2Work tax savings the effective cost would be £245. It's apparently reduced from £599.99 but that could be an inflated RRP?!
    I'd prefer a better known brand with some better forks upfront but I don't think I'd have any complaints for the money. Now I just need the wife to agree it!
  16. techhead
    techhead Minimodder
    17 Jul 2010
  17. B1GBUD
    29 May 2008
    Oooh, that's a nice looking steed. Enjoy!
  18. techhead
    techhead Minimodder
    17 Jul 2010
    I tried to get all the best bits from all the bike shown to me
    air suspension, 2x10 drive train , race face crank, shimano deore XT shadow, hydro brakes
  19. Vault-Tec
    30 Aug 2015
    Good choice. I'm not into mountain bikes but they are the same as everything else, you get out of it what you put into it IMO. Definitely a good idea to buy a last season bike. They are usually pretty much the same only in different colours but with a much lower price tag.
  20. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    That is a lot of bike for £600, well done!
