Windows Cannot install programs - Win 7 64-bit
Discussion in 'Tech Support' started by krazykid035, 9 Dec 2013.
  1. krazykid035
    krazykid035 Entrepreneur
    13 May 2009
    Hello. I am trying to install Google SketchUp and I keep getting this error:
    An error occurred in PreBootstrapper.
    [Could not run setup.exe]
    I tried an sfc /scannow file checker command and it came back fine. I also defaulted the registry for .EXE file associations. Ran as administration, scanned for viruses, tried installing in safe mode... nothing is working.
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Anti Virus stopping it from running? Try disabling whatever you are using.
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Maybe try right clicking your install and selecting run as administrator. Should sort it.
    Sent from my GT-I9505 using Tapatalk
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Check you have updated Windows, specifically any service packs for .NET
    And check there aren't to many files in the Windows Temp folder.
  5. krazykid035
    13 May 2009
    I had ESET disabled and already tried the run as administrator. Cleared TEMP folder and tried different download sources. Hmm
  6. suragh
    suragh Derp
    26 Nov 2011
    This if you haven't already. Give Windows update a try or, repair your .net applications.
  7. Pookie
    4 May 2010
    Does the google exe file run ok on another PC? Also can you run any other installers ok?
  8. krazykid035
    13 May 2009
    Other installers have been acting strange. Typically MSI ones will start to extract, then just disappear and nothing else happens. I have the latest windows update (which did have an update for .net framework). But it still is giving me the error. I do not have another computer to test the install. Just an ipad.
  9. Corky42
    30 Oct 2012
    Anything logged in the Windows event logs ?
  10. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Sounds like a virus to me,remove drive and scan in another pc?
