Modding Case idea ???
Discussion in 'Modding' started by skullen, 27 Apr 2008.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Cut some more bits of acrylic,few holes to do on them,hope to do them this week.
    Some pics of the test fitting,not brill but im happy how it looks so far :)
    Gave the frame a coat of primer,will leave it for a couple of days then spray it white.
    Hope to do a bit more this week then get the case home and start rebuilding,
    Thanks for looking :thumb:
  2. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Im getting there :D
    I sprayed the frame black i think it looks better
    Silver bolts will be swapped for black allen head bolts and the grills will have green ones
    thanks for looking :thumb:
  3. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Central FL
    Dude, this thing's coming along quite fast man! Excellent looking rig already.
  4. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks E.E.L,appreciated :thumb:
  5. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Tennessee
    Great job man, I really dig the design. Maybe you could have the mods move this over to the project logs? I can't wait to see more!
  6. E.E.L. Ambiense
    26 Jul 2007
    Central FL
    Yeah, I meant to say something about that too. It's technically turned into a work-log, so I'd choose a name and ask a mod to move it over.
  7. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks for the replys,much appreciated :thumb:,who do i ask to have it moved :)
  8. Thacrudd
    27 Oct 2006
    Tennessee
    I think you could click on the small red square in the bottom left corner of your posts (under the Avatar) and request it to be moved. I guess that would be a good place to start. Otherwise you could PM Bindi (I think he's the mod for the modding forum)
  9. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks Thacrudd,appreciated :thumb:
  10. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Got my case feet and gatewatch:) covered some of the bits in carbon fibre vinyl,not brill not bad
    Hope to start on the build this week
  11. COMMODORE64
    COMMODORE64 What's a Dremel?
    20 Aug 2008
    Good job man :clap::clap:
    Good to know you have guts to hack X-cruiser! Looking forward to see at end of your worklog.
  12. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks for the reply COMMODORE64,appreciated :thumb:
  13. COMMODORE64
    20 Aug 2008
    Care to pm me how to make a sketch of pc in SketchPad? Please? :) :clap:
  14. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    @ COMMODORE64 you got pm :thumb:
    Still got a few things to do,bay units will be covered in carbon fibre vinyl i think they will look ok with the white acrylic.Got two sets of Bills case feet and im gonna stack them to give me some height on the case.Also im gonna have a go at covering my handles with some carbon fibre vinyl.
    This is what i hope my case will look like when im done.
  15. Loom
    Loom What's a Dremel?
    10 Aug 2008
    Nice work, Skullen! Where did you get the carbon fibre vinyl and how did you cut it? I bought some vinyl from Poundland to start an El Cheapo mod but your post convinced me to do some proper planning first. Keep up the good work!
  16. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks for the reply Loom,appreciated :thumb:
    I get all my vinyl from mnpctech.com and use a sharp blade ,hope this helps :thumb:
    Also on the site is a tutorial on vinyl films :thumb:
  17. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Sint Maarten, Dutch Antilles
    i'm really anticipating this, it's looking pretty good.
    to be honoust, i liked the earlier versions with the bigger door better. Apart from that, the only gripe i have is the handles. I never liked handle, and they add too much black to the design.
  18. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Thanks for the reply Xtrafresh,appreciated :thumb:
    Another pic without the handles.
  19. Loom
    10 Aug 2008
    Thanks, I've checked out the vinyl tutorials. At first I did not like the handles but it's grown on me - I don't know if it's the handles or the black stripes, though - I made a mental image of above picture with 2 black stripes where the handles were and quite liked it. Perhaps it's because it continues the black/carbon fibre theme on the front and side panels.
  20. skullen
    skullen Minimodder
    31 Oct 2007
    uk
    Job done,its not brill there are a few boo boos but i can live with them :D
    Here is the end result.
    A bit cramped in there
    Thanks for all your replys its very much appreciated :thumb:
    Until my next journey into moding hope you like what ive done :D
