Scratch Build – In Progress CaseMod: TARDIS - FINISHED!!!
Discussion in 'Project Logs' started by Pfaffen, 19 Aug 2012.
  1. Cheapskate
    13 May 2007
    I Forgot the doors open inward. That explains all the extra space.
  2. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    On to building the doors...
    You can never have enough clamps.
    Here they are all assembled and drying.
  3. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Of course... I like to add one or two every time I make a purchase over like $50 at the local big box... You always need one more clamp than you have...
    Looking good so far
  4. Toxicgrx
    Toxicgrx What's a Dremel?
    6 May 2010
    Im a fan of Doctor who and i like this mod special in construction progres details. :thumb:
    I, my brother and his son, makes a Tardis Case mod with Antec Lanboy Air.
    our project is 30 hours of work and 10€ its made with recycling materials.
    I'd like to see your progress :)
  5. Pfaffen
    18 Mar 2007
    Nice job!
  6. Pfaffen
    18 Mar 2007
    After looking at the doors, there was a gap between the rails. So I had to make new ones.
    this is what they turned out to be.
  7. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    oooh, nice woodworking! =)
  8. Pfaffen
    18 Mar 2007
    Time to dry fit.
    Here is the front door.
  9. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    In all honesty, it's not my style.
    But with that been said, I can't help but admire the work and the craftmanship that went into this!
    Make no mistake, I think it's awesome! :rock:
  10. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thats really awesome, I love the idea and the execution!
  11. Pfaffen
    18 Mar 2007
    Thanks!
    Having fun building it.
  12. Pfaffen
    18 Mar 2007
    Now we have all four pairs of doors standing.
  13. Owndapwn
    Owndapwn What's a Dremel?
    13 Jul 2012
    How are you doing the ventilation?
    I don't see any fan mountings.
  14. Toxicgrx
    6 May 2010
    In my design i made a ventilation through bottom of case.
  15. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    make sure to fit at least 10x quad 140mm rad : "It's bigger on the inside !" :lol:. Nice job mate :thumb:
  16. Owndapwn
    13 Jul 2012
    I assume it exhausts out the top then?
    Heat rises.
    Fluid convection is very important to remember.
  17. Pfaffen
    18 Mar 2007
    Yes, I planned on venting out the bottom. I also planned on raising the base up .75inch and give the illusion of floating.
    The fan will be mounted in the top, under the light.
  18. Hazmat
    Hazmat What's a Dremel?
    5 Oct 2007
    Very Nice
    Looks awesome! Have you tested any paint yet? Are you going to give it the distressed look?
  19. Pfaffen
    18 Mar 2007
    Mounting the Police Call Box boards. Needed to ensure they were parallel and square. So I cut two templates, put one at the base and you can see the other suspended below the blue tape.
  20. Pfaffen
    18 Mar 2007
    Thanks!
    Haven't tested any paint yet, and am I looking for the distressed TARDIS look.
