I cracked an acrylic res because I over tightened and put too much teflon on the fitting. Quite a newb mistake. I'm really liking this mod, you have been doing a great job. Can't wait to see the finished product.
Sweet Dominator fins, Man. -Who knocked your stars down to 3? We 'gotta fix that. Edit: Well, I got you back to 4. That's a start...
i'm going to fill up the loop now the 3th pump is installed, own mixture : 25% Ethylene Glycol and 75% PURE water, no demi. what you see in the measure cup is the Glycol no color pure 100% glycol : here my koolanc poor in cup on the ZERN res with a snake connector to make it a little bit eassier to fill : on the drain valve i putted also a tube in a bus filled with my mixture, where the pump can draw it's liquid from when i put the valve open, to make it a little bit eassier to lol : and here comes the first liquid lol, pumps are now running to get the last micro bubbles out the loop, for now, no leaks found :
to color it ? or you mean against alge ? Ethylene glycol is from it own against alge. But first run on this, and then there will come an additive in it, that lowers the temps, also anti-alge, anti-corrosion. i only have nickel plated in the loop and acryl, so corrosion will not be a problem.
nope, no color because with color pigment in the liquid you can get this : and without color pigment in the liquid, i will not have that
wow very nice looking. may i ask, where did you get those black alan head screws with the red self locking nuts from?
It's a miracle !!!! i get it closed hahahahaha, +200m cable in limited room of 3,5cm lol : here you see that the plate is a little round, but i put the cable fast fast in to look if i get it closed, later on the cable will be nice routed and strapped so that the plate doesn't look round :
Haha, great video. I love how you roll your tongue on all the "R"s. I presume you're dutch? Also, good to see that the back panel could be closed - my God, that's a huuuuuge amount of cables. DID you shorten all of them, only using the absolutely minimum lengths needed?
OK, I just watched the video. Amazing! I don't even understand half of what you've done there but it's amazing none the less. Well done and +rep.
