Chipped xBox help
Discussion in 'Gaming' started by stevie1556, 4 Apr 2007.
Thread Status:
Not open for further replies.
  1. stevie1556
    stevie1556 What's a Dremel?
    29 Jul 2006
    Hi guys, just wondering if someone could help me out. I got an xBox (first one) last night for £50 includin 2 controllers and 5 games, bargin!
    But here is my problem:
    My nephew who is 6 will be playing on it when he comes over, and if the discs have the same fate as his PS2 discs, they will get badly scratched.
    My solution:
    To get my xBox chipped with these: http://www.kanection.co.uk/product.php/456/27//e07417f2bda67d61235dfd3596038572
    This way I can make a back up copy of the game while keeping the originals safe in the boxes. However, I know you can get a bigger hard drive installed into the xBox, as it uses just a standard 3.5" IDE hard drive. I also know it is possible to transfer the game discs onto the hard drive, which would allow for much faster loading of games, but would that option only become availible after having the mod chip is installed?
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Yes, you have to have a chip installed to run games off your hdd. But i think there is a way arround that by using an exploit, but you need access of another chipped xbox. Your better off to buy a chip, and get a bigger standard ide hdd.
  3. stevie1556
    29 Jul 2006
    I thought the xBox may have 2 be chipped first but I wasn't sure. I was thinking about getting a 160gb hard drive in it for games. I'll be ordering the chip and a new hard drive on tuesday next week ready for a wednesday delivery
  4. bubsterboo
    24 Jan 2006
    Yeah, it needs to be chipped first because you need to use its formatting and ftp features to install the hdd.
  5. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
  6. DougEdey
    5 Jul 2005
    You can do something called a TSOP flash, IMHO, these are only useful on very old XBOXs (v1.0/1.1) as they have solder in the main area you need which is awkward to get rid of. The TSOP flash requires a specific copy of a game (hard to get hold of) and a cable.
    They are awkward to do, but chips IMHO like the Xecuter 2.6 are the best way, I've personally set up lots and they are easy enough to install, it can all be done over the network.
  7. stevie1556
    29 Jul 2006
    Thanks for the info and help guys. I'll check out that link now.
    So can I get an ethernet cable with RJ45 connectors on and connect it to my netgear router to link it to my pc?
    Also, could I connect to the xBox live service using my router?
  8. DougEdey
    5 Jul 2005
    You can connect to XBL using your router anyway, with a chip though it may ban your XBOX, only original games can be used to connect and the chip needs to be off.
  9. mushky
    mushky gimme snails
    24 Mar 2003
    This thread is a blatantly against the rules, regardless of how innocent it may actually be. Xbox-scene has everything you need to know.
    good luck mate :)
  10. Guest-16
    Guest-16 Guest
    As said ^^.
    Mind the doors.
Thread Status:
