Case Mod - In Progress [CIP] Bel Air (Cosmos II) Update 22/05 New sponsor !
Discussion in 'Project Logs' started by alain-s, 26 Apr 2012.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    that looks so awsome :D!
  2. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U all :D
    The build will have a small pause because I need to finish a other Case mod before the 18january 2013 :dremel:
  3. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Such wonderful work, this.
  4. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Nutman :p
    UPDATE !!!!
    After a few months it was time to pick up this project and finish it!
    I continued with the top grill of the case.
    Cutting a Aluminum L profile in to pieces.
    These pieces will hold the support for the aluminum bars of the grill
    All in place. :D
    Next step was to cut every single piece to the exact size. That it all nicely lines up together.
    All pieces in place next up is sanding and polishing the pieces. But that is for next week.
    Got some extra sanding paper its better to have some spare then to come short while u are busy. ^^
  5. FannBlade
    FannBlade What's a Dremel?
    4 Nov 2012
    Thats HOT! Should look amazing buffed out.
    Keep them pics coming.
  6. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Amazing work!
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    nom nom thats sooo damn sexy man!
  8. Asouter
    Asouter --------
    18 Jan 2012
    Really envious of all that sanding and polishing left to do ....(NOT) Your builds are amazing
  9. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Wow I really love your grils, at the top, front, and side.
    However you will needs to handle the dust inside the case ;)
    regards,
    ziza
  10. alain-s
    alain-s Minimodder
    12 Jan 2011
    We will see next week how it will look like :D
    Thank U
    Thx Nate ^^
    Thank U Asouter :)
    Yea well dust gets everywhere just have to learn to clean out the pc ^^
  11. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Cool ideas-can't wait to see final pics. :)
  12. Da Vinci
    Da Vinci What's a Dremel?
    17 Feb 2013
    There are some great Cosmos 2 builds kicking around ATM. Keep up the quality and this will be up there with the best of them! :dremel:
  13. Cheapskate
    13 May 2007
    Ah, That is glorious!:D I don't get why companies can crank out laptops full of die-cast titanium, but can't add metal features like this to a desktop.
  14. The boy 4rm oz
    10 Apr 2008
    Fantastic work on the grill mate, looking sensational so far.
  15. dreps
    dreps Minimodder
    3 Oct 2012
    we want moaaar!
  16. ProZac
    ProZac What's a Dremel?
    24 Nov 2012
    OOh a new update :D Looking awesome dude :D
  17. Vandalo
    Vandalo Minimodder
    24 Mar 2011
    Fantastic!!! great idea.
  18. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Pranja
    Thx Da Vinci will do my best ^^
    Yea would be nice if this grill came standard with the case :p
    Thank U Oz
    Sanding the bars now still need to do them with grid 1000,1500,2000 and then I need to polish them.
    Thank U ProZac
    Thx Vandalo ^^
  19. Nutman
    21 Oct 2008
    Again, fantastic work. The front panel is ALMOST as nicely looking as the one Boddaker is working on right now. ;)
  20. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Nutman ^^
    Update !!
    Last week I received a lovely package from a new sponsor for this project!
    Cooler Master support this project with one of there new PSU series V850 with thanks to Marco from Cooler Master!
    Back to the mod. Started with removing all the extra mounting points from the Noctua fans that I wont need any more.
    [​IMG] [​IMG]
    Added some new material to the build. The original idea was to use walnut wood but do the high price I used regular pinewood. Glued all the pieces together to create one part.
    [​IMG] [​IMG]
    The idea is to do the same things in the case also and color it darker. To finish it I am going to use High gloss clear coat.
    1 side panel is finished already.
