Case Mod - In Progress CL0S3 IMPACT-Final pics and a closing for this saga
Discussion in 'Project Logs' started by B NEGATIVE, 7 Aug 2013.
  1. Cheapskate
    13 May 2007
    Me like!
    Gotta ask, though. Is the backplate pipe a heatpipe, or just a dead-end extension of the loop?
    -NVM, It must be a heatpipe.
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    its a waterchannel but it relies on convection as far as im aware.
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That design looks great!
    And I agree that is one of the most beautiful waterblocks ever made.
    Good luck on this build. Everything you make I really like!
  4. B NEGATIVE
    8 Aug 2011
    Thanks Hukkel!
    :thumb:
    I made a quick and dirty 'playdoh model' ,rather than the full assembly of individual panels that i prefer to do, to have a look at how it fits and looks.
  5. XNine
    XNine What's a Dremel?
    10 Dec 2011
    I like where this is headed. That bay panelling looks excellent, B! Will you make a custom res for it as well?
  6. B NEGATIVE
    8 Aug 2011
    I wont be doing the machine work,thats going out to PARVUM,Nate or Tom at Chilled PC.
    I have designed the res with a bolt on front face but after seeing SEBARs results with a fully bonded res,i may try that myself.
  7. Hukkel
    20 Dec 2012
    Don't forget MWM ;)
    They are great at prototyping and watercooling.
  8. B NEGATIVE
    8 Aug 2011
    I didnt forget,they are in the US tho and shipping+taxes from the US is horrible.
    Which is a shame.
  9. The_Crapman
    5 Dec 2011
    i love those aquacomputer blocks, they're just gorgeous. The front panel res-controller combo looks phenomenal. You could make the back panel of the res from alu block, machined to resemble the block (or other design) and then plated to match. might add a considerable sum to the cost though.
  10. XNine
    10 Dec 2011
    Sick! Can't wait to see how it turns out. Good luck and keep it up!
  11. B NEGATIVE
    8 Aug 2011
    Thats a swish idea Crappy,TO SOLIDWORKS!!!
    Fanx!
    Just got back from i 49,good to see Tom and Sub there along with the Specialtech forum guys,Coolmiester,Namron and the hammer flinger Skully,plus the PARVUM guys (you should see the cases they dont show the world...)
    Anyway...
    I want to fill that gap under the res,I think a touch screen will do very nicely..this one to be precise.
    http://www.lilliputuk.com/monitors/open-frame/of701/
    I will lose around 5mm around the sides and bottom of the screen but i can just resize the display to suit.
    Grills cut in the doors to match the existing S3 slotwork.
    My hand cant heal fast enough im telling you.
  12. Guest-16
    Guest-16 Guest
    Gonna watch the **** out of this thread :rock:
  13. B NEGATIVE
    8 Aug 2011
    Thanks!
    The IMPACT....so much pron in such a iddy biddy form factor,if you dont sell millions of them then there is no justice in the world! :rock:
  14. The_Crapman
    5 Dec 2011
    How is the hand doing?
  15. Asouter
    Asouter --------
    18 Jan 2012
    They're in Holland, I'm sure Sander would be very helpful.
    Here's the link to the FB page
    PM him and he'll answer :)
  16. B NEGATIVE
    8 Aug 2011
    I have PM'd him,lets see what happens neh?
  17. Nexxo
    23 Oct 2001
    Lordy, that's some sweeeeeet little mobo!
  18. B NEGATIVE
    8 Aug 2011
    I have to say the only reason i went ITX is that mobo,its pure pron!
  19. Hukkel
    20 Dec 2012
    I really like the aq5 + res under it design. Finally someone that tries to do something more with a Caselabs.
  20. Nexxo
    23 Oct 2001
    Its gorgeousness just compels you to use it. I found myself instantly redrawing my designs around it.
