Scratch Build – In Progress Combine Ceiling Turret
Discussion in 'Project Logs' started by Mindphaser, 11 Apr 2012.
  1. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Looking good :D
  2. Mindphaser
    Mindphaser What's a Dremel?
    27 Jul 2010
    Combine Ceiling Turret: UPS - update 16/01/13
    Thanks to the Skill3d idea
    decided to build a UPS into the table mount.
    A victim – Powercom WOW-500U:
    Circuit board:
    Cut a USB scheme part:
    Replace battery:
    To embed new components have to increase inner volume, cut side parts and extend a base.
    Approximate layout:
    Relative position of the base and the turret:
    Livio and matiss like this.
  3. Axoxenon
    Axoxenon Do it right the first time
    28 Dec 2012
    Amazing! I found my old HL2 discs a while ago and just finished the first part yesterday.
    Subscribing to this awesomeness! Cant wait for finished mod :D
  4. matiss
    matiss Minimodder
    24 Jun 2010
    Looking great and cool inspiration
    +1 for Frontline Assembly :D
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Brilliant, so inventive. :clap:
  6. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Awesome updates since last time I looked. Fantastic craftsmanship !!
    Sent from my Nexus 7 using Tapatalk 4
  7. Cheapskate
    13 May 2007
    Wild! I love what you are doing.:D
  8. Mindphaser
    27 Jul 2010
    Painting started
    A long time ago, in a far, far Ukraine this log were started…
    Now I want to see the turret assembled shortly, so left the UPS-base.
    Swivel lid frame
    Lid front panel
    Swivel lid assembled
    Lid fixed on frame in close position:
    Opened position
    After numerous “filling-gringing”cycles, some parts are ready for painting.
    Prime paint and base colors are spray paints.
    DVD-box two color (in process, with mask):
    Swivel lid base color:
    After red mask removing:
    Both swivel lid and DVD-box:
    Another side of lid, paper mask, wetted:
    Chipped paint imitation by the kitchen salt:
    Painting:
    Mask removed, you can see the wet surface:
    Cleaned surface:
    Next time I’ve planned to apply some effects – aging, graze, rust.
  9. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Wow, suddenly back from history - this is looking really nice.
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    It's been a long time. Nice to see you back, buddy.
  11. Mindphaser
    27 Jul 2010
    Painting continued...
    Mockingbird and Pranja, thank you. Glad to back to the modders community. :rock:
    Weathering effects make with acrylic paints. No aerograph used – only
    “hand tools” such as matches, toothpicks, ear cotton sticks, bath sponge and kitchen cleansers.
    And here is the result:
    Well, now it doesn’t look like a piece of fresh painted plastic :D
  12. Mindphaser
    27 Jul 2010
    Painting still continued...
    It’s time to apply some weathering effects to the case swivel lid:
    View from another side:
    Exhaust grille:
  13. Mindphaser
    27 Jul 2010
    Painting still continued...two
    A little experiment with texture on the lid front surface:
  14. Mindphaser
    27 Jul 2010
    Painting still continued...three
    Try a new method of rust imitation:
  15. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    very nice paintwork and wethering effects love the rust too seams almost real. :thumb:
  16. morgansk
    morgansk I've got wood
    12 Jan 2013
    Awesome paintwork. I have often wondered how some paint effects are created, love the table salt trick!
  17. Cheapskate
    13 May 2007
    Awesome! Good to see you back.:D
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hope you complete this, it's awesome. :)
  19. The_Crapman
    5 Dec 2011
    The detail in the paintwork is superb. Looking forward to seeing this finished.
  20. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed! Better late than never. :)
