PSU Confused on DC-DC power supply wattage.
Discussion in 'Tech Support' started by Mokey Mokey, 4 Jun 2009.
  1. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    I'm looking at getting a 200W DC-DC power supply (here) for an HTPC.
    What I am confused about is do I need an AC-DC external power adapter that has an output of 200W in order to get 200W out of the DC-DC?
  2. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    if you want to run it from AC (mains power) then you will need a AC to DC converter of the same wattage in order for it to function.
  3. Krikkit
    21 Jan 2003
    You'll need a mains transformer of at least 200W to power it.
  4. Mokey Mokey
    9 Mar 2009
    Thanks guys! :D
    Edit: Do you know where I can find a 200W or higher AC-DC power adapter? The highest I can find is 150W.
