Confusis's folding rigs plans
Discussion in 'bit-tech Folding Team' started by confusis, 11 Mar 2010.
  1. confusis
    confusis Kiwi-modder
    5 Jan 2006
    I'm at the point with this xeon board now I'm looking for cheap opteron 940 dual cores! (so I can SMP). Gah i hate broken hardware :(
    Anyone have any?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    What model xeons? What case would they be in? Do you like a lot of noise?
  3. confusis
    5 Jan 2006
    They're in a 5u rackmount case. Well the noise factor may not matter too much as the damn board won't work
  4. confusis
    5 Jan 2006
    For the same price I can buy two dual core 2.2 opterons or a 9600GT. This will be going into the ASUS K8N-DRE board. Which would get the highest PPD? Of course they will both be done at some point but which should be first? Basically i'm asking SMP or GPU...
  5. saspro
    saspro IT monkey
    23 Apr 2009
    I'd say the gpu will get more points.
    Old cpu's seem to take ages folding SMP's
  6. Tesla effect
    Tesla effect AKA ZombieKiller1
    24 Jul 2009
    I dont think there's much in it but I would've thought a quad core SMP box folding a3 WUs will beat the 9600GT even with low clocks. Would the Opterons not be roughly comparable to a Q6600 at stock 3-4K PPD maybe more? The 9600GT I think will be closer to the 3K mark but you will be able to OC the shader clock & hopefully squeeze out a little bit extra performance.
  7. confusis
    5 Jan 2006
    Will have to have a look at the board o/cing when it gets here.
  8. Tesla effect
    24 Jul 2009
    Confusis your planning on buying these right?
    AMD Opteron 275 HE Italy 2.2GHz 2 x 1MB L2 Cache 1GHz HT.
    That's a total of 4MB L2 cache with 2 of these, the proc spec /the DRE board only supports DDR1. A Q6600 has 8M L2 cache shared & supports DDR2 so I'm thinking they will probably produce closer to 3K PPD.
    How much CPU time will you be using for file sharing etc? This will obviously impact on the folding peformance whereas the GPU isn't going to be slowed down.
  9. confusis
    5 Jan 2006
    Yep, Tesla that's them.
    CPU time for file sharing will be minimal - mostly going to be a backup server for now.
    Only looking at the dual core opterons as I have already paid for the board!
    Looking at those numbers I should go for the card first.
    Would be nice to get the xeon board going too but nobody seems to be helping much over in the Tech Support forum! (the help so far has been good though)
  10. confusis
    5 Jan 2006
    Is the GT240 worth NZ$12 more than a 9600GT? (8% more in price) in terms of PPD?
  11. confusis
    5 Jan 2006
    Ok I'm officially addicted. Just bought two more dual xeon boards. D'oh! Oh well 3x xeon smp machines soon then hopefully. Time to design a custom case!
  12. Tesla effect
    24 Jul 2009
    Get the GT240 instead it's a better folder & is more power efficient.
  13. confusis
    5 Jan 2006
    cool! thanks for the advice. (just so happens the 9600gt is out of stock at my normal supplier too)
  14. confusis
    5 Jan 2006
    Cool, all my boards have arrived. Will hopefully have one or two going tonight. It sucks I have to go to work when there's systems to build!
  15. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Good luck with the builds :thumb:
  16. confusis
    5 Jan 2006
    Just plugged in the power adapter to the server grade psu in my e-atx case.
    Turned it on, expecting to hear it single beep for successful boot.
    Except I see a flash of electric blue/white light from the psu.
    Will dissect it tommorow to see if it's hopefully a fuse. I do have two spare 603 boards if this board is loading it too much - they don't require the 8pin power plug and are atx not eatx :)
  17. confusis
    5 Jan 2006
    It was only a fuse. Will replace today. I moved the xeons to my new Tyan atx boards, and on a lower wattage PSU. Starts fine! Will install win2k3 later today and get it folding.
    Where's my spare pc speaker.... this one isn't posting either x.x
  18. confusis
    5 Jan 2006
    Nope it blew the psu and fuse.
    The 8pin adapter was the wrong design so i've probably blown the board, and maybe the cpus too. Will wait for a response from the ebay seller.
    The yellow and black wires were transposed, and two yellow wires were connected to the 5v pin on the molex plugs!
    EDIT:
    Now I'm still looking for dual core 940 opterons, coolers and a psu to suit. ><
  19. 1Razor
    1Razor Living life one day at a time....
    24 Apr 2009
    Unlucky dude, seems it's not your month for hardware!
  20. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    Damn that is some serious bad luck dude! Isn't the yellow wires supposed to be 12v!? Why did the seller move them??
