Case Mod - In Progress Cooler Master Cosmos II MbK...Final pics!!!
Discussion in 'Project Logs' started by kier, 2 Jan 2012.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I would rather say like this:
    -I hate you Richard !
    I had the exactly same idea for the top and the bottom chamber(almost) but with an tripple rad-guard instead ;D
    Keep on the good work mate and good luck :D!
  2. JdotH
    JdotH What's a Dremel?
    10 Jan 2012
    Kier, I am very pleased to see your efforts.
    Are you going to do a window?
    Seeing as there isnt one, and most people want to actually see their nifty/expensive stuff inside, you should do an uber window.
    Like maybe a window that is double paned so that the liquid cooling can go through it....and in the window you could have your sponsors or some feature for the liquid to pass around/over....oh and quick disconnects so the door can still be removed.
    Either way...I am thrilled to see you hadeling this case.
    Cheers.
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Subbed!!
    Based on your previous work this is going to be an amazing mod!
    Looking at this case more and more and thinking of getting one myself as it look's like it could, hold a Quad 120mm rad at the top and 1 in the bottom with a Dual 120mm rad as well.
    Still trying to decide what case to use for my next build, but it need's plenty of space for all the rad's I want.
    Anyway will be keeping an eye on this.
  4. kier
    kier -----------------
    1 Mar 2011
    Update: The front
    These last few days i've continued with the appearance of the case. I want the front to turn black / white. So I have sawn a piece 3mm black acrylic, the same pattern as the white plate. Only now with the recesses 5mm smaller.
    White plate on it
    I like the looks of it. Also have now some great air in/ outlets, finishing of this part later
    I previously mentioned that the controller is coming in the upper 5.25 compartment togheter with the I/O stuff, all of this in the black and white theme
    So marked a 5mm white acrylic piece
    To keep everything in place there is coming a piece of black acrylic behind it with recesses for the controller and I/O stuff
    Witch is placed like this
    To get a nice contrast around the controller, I've cut and filed a edge of 3mm black acrylic
    And also made two black strips cut for the I/O stuff
    And placed in the Cosmos
    For the lower I/O section cut rectangles and circles for the USB and audio
    And after some carefully filing
    Top I / O section also done, and put everything in it for the looks
    Above the Cosmos controller is still a big white surface, this seems to me a nice place to put a display.
    For this the perfect display: The Aquaero 5 XT. So ordered and received
    Hmm that's a unpleasant surprise, the controller with touch buttons isn't black anymore (like the older version) but Aqua Computer has replaced / filled this with stainless steel buttons.
    Itself is looking very nice with the new buttons... but not for this build. So first i'm going to try to get an "older" version. Until I know more I will stop working out the display.
    That's it my modding friends ;)
    weatherdown and dmcgrath like this.
  5. dmcgrath
    dmcgrath Master of Pancakes
    14 Aug 2011
    Ah wow, I love the treatment you did on the front there. I'm still mulling around where all my connectors are going to go back into my mod. :) This is noteworthy
  6. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Wow.. just.. wow O.O
  7. Sarakon
    Sarakon The German
    11 Feb 2011
    That front is really awesome, suits the case really well :thumb:
  8. weatherdown
    weatherdown What's this button fo......
    27 Dec 2011
    love the contrast look
  9. kier
    1 Mar 2011
    Update
    Just a small update about the cover at the right bottom.
    First idea was to make this cover with a angle just like the other side, but a change of plans.
    This is now becoming a straight cover, but with 2 HDD attached to it. The place for the HDD's was a bit limited because I removed the HDD cages and almost all the space is occupied by the water cooling products
    So this is a nice solution. There will also be a SSD, but this is placed on the side of the 5.25 bay
    For the cover I sawn a piece aluminum and marked it
    Bent it
    Cut out the Fanholes again
    And drilled the holes for the HDDs. Of course I will make some adjustments for noise reduction
    All placed like this
    Also made the recess for the cables
  10. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Looking good Kier!
  11. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    looking very nice =)
    i want to get sponsored by cooler master for a Cosmos 2 Got loads of ideas floating around !
  12. Cheapskate
    13 May 2007
    :lol: So there's enough space in the bottom chamber to mount drives vertically? -friggen HUGE, man! Brilliant placement, BTW.:D
  13. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    Your just:
    **** YEA xD
    Great job, will follow it for sure
  14. kier
    1 Mar 2011
    Just a small addition:)
    I've covered the two plates with black vinyl, which gives the same black color as the rest of the case
    And placed them
    Pics with the white front
  15. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Good job. Now,please MOAR. :D
  16. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    That looks OSM!
    Subbed without a doubt.
  17. renrenderla
    renrenderla What's a Dremel?
    22 Aug 2010
    Looking Good! More updates please! :)
  18. kier
    1 Mar 2011
    Update!!!
    I would like to welcome a great sponsor for this build, the shop that has everything .... IT-Service.be
    IT- service/ Eddy Thanks for the nice discounts.
    For this build I purchased a nice new mobo: The Asus SABERTOOTH X79
    Really a great motherboard, here some pics:
    Some standard stuff
    And the motherboard
    Placed right away in the cosmos
    So the Sabertooth, really is a beautiful mobo
    I also bought some beautiful rams to fill up the sabertooth, 3 x the Corsair 4 GB DDR3-1600 Kit
    I will place EK ram coolers on these.
    En last but not least, the white Xigmatek XOF-F1251 fans, which fit perfectly with this build
    Placed on top
    360 rad fits
    In the last update I had shown you the white midplate, Ive adjusted it a bit for 2 pumps
    Which will be placed like this
    Received approval from my great friend
    And also cut a white acrylic plate for the mobo tray
    Beneath and beside the motherboard I have a lot of space, this will be filled up;)
    I would like the same line as the EK tops, and I want a nice light distribution in terms of the illuminated midplate. For this I am going to raise the midplate about 4 cm, for this I have sawn and bent an aluminum strip cut
    Behind it I placed 2 CFL lights, and we have an illuminated midplate
    For an even better light distribution I will do some adjustments, but more on this later.
    I've made a bracket for the rad
    I still need to make the top bracket but this I will do later
    Enough room for the fittings
    And here the radiator with fans
    Applied a layer vinyl coating to the strip
    Looking good I think :D
    Grtzzz ;)
  19. dark4181
    3 Jan 2008
    Holy crap O.O
  20. r1sKas
    22 Jan 2011
    Love your fans m8!
    Keep going your good work ;D
