Hi there, Is the Coolermaster Extreme Powerplus any good and will it do a decent job for this build- CPU: AMD AM3 Phenom II x4 925, 2.80GHz, Quad-Core. Motherboard: Asus M4A79XTD-EVO. Graphics Card: HIS 1GB 5850 PCI-E VGA Card. Hard Drive: SATA Seagate 500GB HDD . Optical Drive: SATA Asus Black DVD-RW. RAM: G.Skill-NT 4GB DDR3 1333MHz. Case: Antec 200v2 Power Supply: Coolermaster extreme power plus 600watt Kind Regards, Westham101
go for the antec 650w modular powersupply http://www.scan.co.uk/Products/650W...f-SLI-CrossFire-EPS-12V-20plus4-Pin-120mm-Fan
Thanks, here are my updated specs....... you think that will be a good enough powersupply? CPU: AMD AM3 Phenom II x4 925, 2.80GHz, Quad-Core. Motherboard: Asus M4A79XTD-EVO. Graphics Card: HIS 1GB 5850 PCI-E VGA card Hard Drive: SATA Seagate 500GB HDD . Optical Drive: SATA Samsung Black DVD-RW. RAM: G.Skill-NT 4GB DDR3 1333MHz. Case: Antec 200v2 Power Supply: Antec Truepower TP-650watt
I think Jipa was just making the point that a 650 watt would be very safe as his system is unlikely to ever draw more then 400w. Not that he should get a 400w PSU.
